Page 5 of 6 FirstFirst ... 3456 LastLast
Results 61 to 75 of 89
Thread: Texas Mile 2019 on the Energica EGO
  1. #61
    37 miles E. of ATX, TX USA.
    I’ll onlu have 30A available at track so power flow into bike will be somewhat limited. Hopefully today I get another round of testing in prior to next dyno bike.
    Micah Shoemaker
    9900 IH35N
    Austin, TX 78753
    micah@af1racing.com
    @ShoemakerMicah
    @AF1Racingaustin
  2. #62
    apriliaforum expert LUCKY DAVE's Avatar
    Sep 2005
    Encinitas, ca
    Micah, how many cells are in the bike's battery pack? They are probably cells just like the ones we use, but we only have two and relatively exposed to cooling air, so we can get away with charging at 20-35A/cell. That would equate to charging at thousands of amps on the bike? I doubt you could manage that without thermal runaway.
    A finish is a win! Moderation is the key! More wine!
    And never lend a faggot your hat
    Proud Member of Team Punisher and The Texas Mile 200 MPH club
    Motorcycles are not just fun toys. They are a catalyst for the enjoyment of life. - NaimChase
    When you ride a bike that tries to crawl out from underneath you at 150MPH with a slight twist you know you're on the right path. - TRexRacing
  3. #63
    Hundreds, literally. Flat pack/rectangular plate style. It’s strapped to dyno charging for a below freezing test in morning as I’m getting one part in controller warm and once it exceeds 37C amperage is reduced.
    Micah Shoemaker
    9900 IH35N
    Austin, TX 78753
    micah@af1racing.com
    @ShoemakerMicah
    @AF1Racingaustin
  4. #64
    Sep 2005
    Encinitas, ca
    Just two cells can deliver ~2hp when pushed to thermal limits.
    The 1500 gram cars we race have approximately 2000 scale hp. Yeah, they're really hard to drive at first, but once you get used to it (it takes a lot of "seat time" to develop the required skills) and figure out the chassis setup they are amazingly fast with incredible corner grip on a prepared clay surface with the moisture content just right.
    Turning the car in the air over big triple jumps to line up with the next fast sweeper is routine....you have to hit your marks within an inch or two every lap to be competitive.
  5. #65
    Sep 2005
    Encinitas, ca
    It sounds like you need a CO2 bottle bleeding on the controller to control the temps.
  6. #66
    The controller is water cooled by a Bosch water to air intercooler pump but the first part to exceed 37C does not trigger pump. It’s hotwired for morning test and FULLY charged. If I need to create a special N2 or CO2 cooling channel for this part...fuck, I will, not sure hw yet, but I will because if I run it in Bolivia or SCTA I’m gonna need WAY more than 22 seconds of full power
    Micah Shoemaker
    9900 IH35N
    Austin, TX 78753
    micah@af1racing.com
    @ShoemakerMicah
    @AF1Racingaustin
  7. #67
    Sep 2005
    Encinitas, ca
    CO2 is far more practical than N2, it is a stable liquid at room temperature (think common fire extinguisher) and as such there is a lot of heat to be absorbed in a small bottle.
  8. #68
    I’m moving to a “road” testing phase,the bike seems to know it’s on a dyno and is reducing power after 4-5 seconds WFO even maintaining 0-12C in controller this morning at zero dark thirty in the snow. That said, over 250 ftblbs is possible on launch at 400 amps delivered to motor at 335V...it’s like batshit crazy torque! That’s with the tallest gear ratio on the market....exactly the same unsurprising as the stock sprocket ratio...lol, keep have to remember to input standard temp, pressure and humidity for zero atmospheric trim on dyno.
    Micah Shoemaker
    9900 IH35N
    Austin, TX 78753
    micah@af1racing.com
    @ShoemakerMicah
    @AF1Racingaustin
  9. #69
    apriliaforum expert derbybrit1's Avatar
    Feb 2005
    San Dimas, CA
    LuckyDave said something about Micah looking for a shortened shock? I have a shortened Sachs from The Punisher Texas Mile project. You are welcome to it if you think you can use it.
    Team Punisher/AF1 Racing:
    World's Fastest Aprilia RSV 200.8mph
    Texas Mile Record Holder - Fastest Twin
    2014/2015 Moto West Grand Prix Formula Singles Champion
    2016 WERA West Clubman Expert and D Superbike Champion
  10. #70
    Can you send me dimensions in case my Öhlins unit doesn’t work out? Need to find a place to do some “road” testing ASAP. The bike knows from its IMU if it is on a dyno, you only get almost full power for 4-5 seconds and it’s not temperature dependent. I had no such issues in first “road” test on stock gearing.
    Micah Shoemaker
    9900 IH35N
    Austin, TX 78753
    micah@af1racing.com
    @ShoemakerMicah
    @AF1Racingaustin
  11. #71
    apriliaforum Member kneepucker's Avatar
    Jun 2016
    Dallas, TX
    Dude, 130 Toll between Hutto and the 45, middle of the day. Even if you get pipped by the fuzz, just explain what you're trying to do. It happened to me on my racebike with number plates and no headlight; cop was totally chill and let me go.
  12. #72
    Austin, TX
    Only two weeks until our next racing event... We are taking our all-electric, all-Italian Energica Ego for some top speed runs at the Texas Mile event.
    Piloting our bike will be Erin Sills, a 30-time land speed record holder, and she has gone over 240mph before. Read more about her amazing racing career here: http://huntersillsracing.com/
    We will also have a very special pit crew helping us go fast and set new records. Krystal Hess, and some veterans from her Motorcycle Missions organization will be on hand to assist in our efforts. Motorcycle Missions is a local Austin non-profit organization dedicated to helping veterans and 1st responders with PTSD through motorcycles. Please check out their website, and please donate to their very worthy cause.
    http://motorcycle-missions.org/
    "At Motorcycle Missions we understand that much of the post traumatic stress (disorder) paradigm is that the need for purpose, camaraderie, and adrenaline is of the utmost importance. Our hope is to encourage our audience to instill a life-long passion for motorcycling, that will help them enjoy a happy, healthy, and balanced lifestyle after trauma."
    Texas Mile Event Details: http://texasmile.net/texas-mile/ Stop by our pit, meet the whole team, and check out the bike.
    Energica Ego - EXCITEMENT THAT’S MORE THAN JUST POWER. The heart of the Energica Ego is a synchronous oil-cooled motor with permanent magnets and a 11.7 kW lithium polymer battery. This delivers instantaneous and linear power, and torque far surpassing internal combustion engines of any sportbike. At 148 ft. lbs. of torque the Ego is capable of accelerating from 0 to 60 mph in under three seconds. With a factory limited top speed of 150mph, AF1 Racing has a few tricks up its sleeves that should push it well past 150mph. Read more about the bike here: http://www.energicamotorusa.com
  13. #73
    apriliaforum expert JAndrewG's Avatar
    Nov 2008
    Silverdale WA
    Thanks for the update Ed. I've been watching for news on this.
    Sounds like you have a capable and competent crew and pilot. Wishing you all the best on this venture!
    John
    Akrapovic full system, NERA top triple clamp, Aprilia accessory rear sets, AF1 Ti bolt kit, etc. etc...
    2007 Ducati GT 1000, red
  14. #74
    apriliaforum expert Hellgate's Avatar
    Mar 2009
    AUSTX
    Man, what an awesome team! I think I met Erin about 8 years ago at a random party. Did she used to ride blown Busas? If not... I've not met her.
    Pete
  15. #75
    Nov 2008
    Silverdale WA
    Guess they're at the Texas Mile now doing some runs. Good Luck! Looking forward to hearing how it went. And pictures. Pictures would be nice.
    John
  1. Turned 60,000 miles today on the 2010 RSV4F
    By klowry in forum 2010-2019 RSV4 - All Variants
    Last Post: 11-06-2016, 08:47 AM
  2. 1400 mile trip on the Beo
    By Silas Fegan in forum Aprilia and Piaggio 500cc
    Last Post: 01-07-2012, 03:44 AM
  3. Help me with a 4000 mile trip on the T...
    By pilotw98 in forum Tuono 1000 R and Tuono Factory (2006-2010)
    Last Post: 05-05-2011, 08:22 PM
  4. How many miles/km on the clock?
    By oldbandit in forum RS125 Euro-archive
    Last Post: 04-07-2005, 12:02 PM
  5. Survey-How many miles on the Falco now?
    By biggums in forum SL1000 Falco Forum (all years)
    Last Post: 03-28-2003, 03:01 PM
