Page 4 of 6 FirstFirst ... 23456 LastLast
Results 46 to 60 of 89
Thread: Texas Mile 2019 on the Energica EGO
  1. #46
    37 miles E. of ATX, TX USA.
    No yet. Bike is cranking some serious power down nw, 18-19 tooth front sprockets on order, 36 rear. Running into thermal limits as I’m pushing almost 400 amps across controller. I need 22 seconds of full power, highest number generated yet has been 178 ft/lbs of torque launching from 25 mph.
    Micah Shoemaker
    9900 IH35N
    Austin, TX 78753
    micah@af1racing.com
    @ShoemakerMicah
    @AF1Racingaustin
  2. #47
    apriliaforum expert JAndrewG's Avatar
    Nov 2008
    Silverdale WA
    178 pounds of torque. Amazing.
    Since gearing is mostly about multiplying torque, and electric motors make power from zero RPM, the tall gearing probably has little effect out of the hole?
    John
    Akrapovic full system, NERA top triple clamp, Aprilia accessory rear sets, AF1 Ti bolt kit, etc. etc...
    2007 Ducati GT 1000, red
  3. #48
    Nov 2006
    Houston
    178ft-lbs?? That sounds seriously serious. Perhaps you need to supercool the controller in a liquid N bath.
    Bikes:
  4. #49
    I’m not opposed to CO2 cooling the battery, controller and AC wires. It’s cheap and easy, done it on cars. I NEED 400 amps for at least 17-18 seconds to go 170-180 mph at sea level. 18-19-35 T sprockets already incoming. Real question is, does more torque/lower motor rpm go faster than allowing motor to spin faster on an electric bike.
    Micah Shoemaker
    9900 IH35N
    Austin, TX 78753
    micah@af1racing.com
    @ShoemakerMicah
    @AF1Racingaustin
  5. #50
    Nov 2006
    Houston
    N would be better.
    Bikes:
  6. #51
    Nitrogen is fine, readily available, huge drop in temp from entropy bebtween liquid and gaseous state.
    Micah Shoemaker
    9900 IH35N
    Austin, TX 78753
    micah@af1racing.com
    @ShoemakerMicah
    @AF1Racingaustin
  7. #52
    Latent heat is a wonderful thing!
    Professional Goat Burster.
  8. #53
    apriliaforum expert LUCKY DAVE's Avatar
    Sep 2005
    Encinitas, ca
    Remember that tall-as-a-mountain tire we needed to get enough gearing on the Punisher?
    200/50?
    Move the footpegs as needed to get your feet out of the air stream and cut the bars as short as you can, it made a big difference with the Punisher.
    A finish is a win! Moderation is the key! More wine!
    And never lend a faggot your hat
    Proud Member of Team Punisher and The Texas Mile 200 MPH club
    Motorcycles are not just fun toys. They are a catalyst for the enjoyment of life. - NaimChase
    When you ride a bike that tries to crawl out from underneath you at 150MPH with a slight twist you know you're on the right path. - TRexRacing
  9. #54
    Sep 2005
    Encinitas, ca
    It should. The torque falls off quickly with rpm in electric motors, max torque is at locked rotor.
  10. #55
    Sep 2005
    Encinitas, ca
    I NEED 400 amps for at least 17-18 seconds....
    Maybe not, the motor pulls max amps at zero speed, amp draw should fall off with rising rpm.
    Can you measure this on the dyno?
  11. #56
    Yes Dave, it’s a 3 phase PWM AC motor, Launch amperage, is about 380 amps, which it maintains initial a certain sensor in inverter comes on a 37C temp and starts throttling back power. Oddly the inverter never gets warm Anouilh in general to turbo on its electric water cooling system so today’s test is to force that one with diagnostic software and see what happens. I’m of the opinion the best speed will come with the tallest possible gearing on an electric, hence my desire to try 19-36 next. Stock was 16:44
    Micah Shoemaker
    9900 IH35N
    Austin, TX 78753
    micah@af1racing.com
    @ShoemakerMicah
    @AF1Racingaustin
  12. #57
    Sep 2005
    Encinitas, ca
    Micah, you may recall that in addition to my other pursuits I am a weekly (electric powered) RC car racer.
    These are also variable frequency three phase ac drives, there is likely some similarity to the strategy for going fast as your mile project. RC racers have been at this a long time, and like all racers they have experimented with making things go faster.
    RC racing is big business in places where it's cold in the winter or where land is too expensive to build full size tracks (Japan and Europe for example) so there are pro racers that make upwards of $100K/year to do this, and it turns out that a handful of them live local to me and race at my home track every Wednesday night. I race two and four wheel drive, I'm an average racer in the intermediate class, when the Pro class runs it's worth walking out of the pits to watch, as they're as good as the top dogs in any other form of racing.
    Anyway....the RC world has discovered that high amperage charging of the LiPo batteries drives up the voltage (a lot) giving a distinct power boost during the first thirty seconds or so of the (5 to 7 minutes long) race. We typically charge tiny 2 cell battery packs at 40-70 amps.
    I strongly urge you to look into the RC racing world to find out the latest charging methods to make variable freq ac motors scream bloody horsepower.
  13. #58
    apriliaforum expert yzr750's Avatar
    Dec 2011
    Brisbane Australia
    Quote Originally Posted by LUCKY DAVE View Post
    That's interesting, what does that do to the longevity of the battery pack?
    seesecurity.com.au
  14. #59
    Sep 2005
    Encinitas, ca
    Quote Originally Posted by yzr750 View Post
    Shortens it, and you have to monitor battery temperature during charging as fire is a possibility.
    Why do this?
    Cause Racing.......
  15. #60
    Sep 2005
    Encinitas, ca
    The purpose of the heavy ampere "balance" charge/discharge cycles we routinely put our batteries through is to lower internal impedance (internal resistance to current flow). Cycling a battery with (the typical) 7-10 ohms impedance through 40 amp charge/discharge cycles a couple times usually lowers the impedence to <1ohm.
    Less impedance, more current flow = more power.
  1. Turned 60,000 miles today on the 2010 RSV4F
    By klowry in forum 2010-2019 RSV4 - All Variants
    Last Post: 11-06-2016, 08:47 AM
  2. 1400 mile trip on the Beo
    By Silas Fegan in forum Aprilia and Piaggio 500cc
    Last Post: 01-07-2012, 03:44 AM
  3. Help me with a 4000 mile trip on the T...
    By pilotw98 in forum Tuono 1000 R and Tuono Factory (2006-2010)
    Last Post: 05-05-2011, 08:22 PM
  4. How many miles/km on the clock?
    By oldbandit in forum RS125 Euro-archive
    Last Post: 04-07-2005, 12:02 PM
  5. Survey-How many miles on the Falco now?
    By biggums in forum SL1000 Falco Forum (all years)
    Last Post: 03-28-2003, 03:01 PM
