Page 2 of 6 FirstFirst 1234 ... LastLast
Results 16 to 30 of 89
Thread: Texas Mile 2019 on the Energica EGO
    Nov 2006
    Houston
    You going to fashion some covers for the headlights? They don't look all that aerodynamic. Beautiful bike though. Be interesting to see some dyno curves.
    Bikes:
    apriliaforum Member kneepucker's Avatar
    Jun 2016
    Dallas, TX
    Are you able to swap out the front hugger to one that comes down farther and doesn't catch the air like a sail; Or does Energetica want you to leave the aesthetics alone for the most part?
    37 miles E. of ATX, TX USA.
    Thatís an at the track swappable part if needed. The RSV4 steering damper is now on, just had to make one special stud to adapt to the Energica lower triple clamp. They use M8 holes on outside edges, Aprilia M6 holes....so an RS250 exhaust stud was turned into this, an M8 to M6 stud....having a lathe is awesomeness!
    Micah Shoemaker
    9900 IH35N
    Austin, TX 78753
    micah@af1racing.com
    @ShoemakerMicah
    @AF1Racingaustin
    Street testing commenced, dyno tomorrow before lowering the bike so as not to scratch the carbon belly pan. Introducing our guest rider shortly, suffice it to say she has the bona fides to go fast if anyone does!
    Micah Shoemaker
    9900 IH35N
    Austin, TX 78753
    micah@af1racing.com
    @ShoemakerMicah
    @AF1Racingaustin
    apriliaforum expert yzr750's Avatar
    Dec 2011
    Brisbane Australia
    Iím thinking if the wind favors us 165-170, leaves a lot of room for improvement in subsequent events while placeholding the standing mile record right?
    Is it not a two way run?
    seesecurity.com.au
    If you want to show how miserably slow an un-aerodynamic version might be Jude and I will happily fly over at our own expense and I will selflessly volunteer to don the 'Sausage Suit' for one last time just to prove that no matter how dedicated you are an old, fat, idiot can spoil it every time!
    Really. I think this is brilliant! You blokes and blokesses are going to be around when this technology becomes both the norm and the future! Remember when the people with horses and single action steam engines said internal combustion engines would never catch on? Neither do I! Not even I'm that old? But it happened.
    We don't have an importer or dealer in Oz. I'd crawl seven miles over broken glass to stick matches in someone's turds to be at the cutting edge of fun like this.
    Go for it guys. Go hard! Fat old people are depending on you!
    Pete
    Professional Goat Burster.
    Nov 2011
    devil's elbow, oz
    17/38 final ratio should let it stretch it's legs Micah. Does the bike have any launch or wheelie control?
    From what I've read it has the whole suite of 'Rider assists'. I'm happy to be corrected.
    apriliaforum expert vfr1200's Avatar
    Jun 2011
    Azle, Texas
    We're all stringbeans.
    I'm 6'-0" & 160 lbs.
    2017 Sherco 300 SER Factory
    2016 Tuono 1100 Factory
    2015 TREK 7.3
    https://www.amazon.com/s/ref=nb_sb_n...alan+golightly
    This bike, and no pre 2019/20 Energica without $3k upgrade package have any traction control, launch assist or what we think of as rider aids. Wheelie control is not really needed, the weight of the battery ensures that, I can make it wheelie, but that’s almost 3 decades of technique required. Hit 151mph testing yesterday at 9650 motor rpm....motor is supposed to go to 10500 so if the ecu is getting its limited data from ABS sensors...well, I have a fix for that coming right up, no time to do it like when wheels are off for sprocket swap lol.
    Hoping to get the MotoE firmware update....more amps, SLIGHTLY higher armature rpm.
    Micah Shoemaker
    9900 IH35N
    Austin, TX 78753
    micah@af1racing.com
    @ShoemakerMicah
    @AF1Racingaustin
    Nov 2006
    Houston
    151mph? What would the range be at that velocity? Sucker kinda hauls ass.
    Bikes:
    Mar 2012
    On the road between ID & OR
    Hopefully, the better part of a mile.
    JD
    Futura
    Bunch of dirtbikes
    I can cheat speed limiter if speedo based easily, cut out every other rib from the abs tone wheels...done. If itís rpm on motor based and can pull gearing Iíll either have to use MotoE mapping (still might) or just get the most I can out of 9650 motor rpm...
    here is my RSV4RR steering damper conversion complete....thoughts?
    Micah Shoemaker
    9900 IH35N
    Austin, TX 78753
    micah@af1racing.com
    @ShoemakerMicah
    @AF1Racingaustin
    Mar 2012
    Looks like it belongs there.
    JD
    Futura
    Bunch of dirtbikes
    After three hours fab and mounting time it better lol
    Micah Shoemaker
    9900 IH35N
    Austin, TX 78753
    micah@af1racing.com
    @ShoemakerMicah
    @AF1Racingaustin
  1. Turned 60,000 miles today on the 2010 RSV4F
    By klowry in forum 2010-2019 RSV4 - All Variants
    Last Post: 11-06-2016, 08:47 AM
  2. 1400 mile trip on the Beo
    By Silas Fegan in forum Aprilia and Piaggio 500cc
    Last Post: 01-07-2012, 03:44 AM
  3. Help me with a 4000 mile trip on the T...
    By pilotw98 in forum Tuono 1000 R and Tuono Factory (2006-2010)
    Last Post: 05-05-2011, 08:22 PM
  4. How many miles/km on the clock?
    By oldbandit in forum RS125 Euro-archive
    Last Post: 04-07-2005, 12:02 PM
  5. Survey-How many miles on the Falco now?
    By biggums in forum SL1000 Falco Forum (all years)
    Last Post: 03-28-2003, 03:01 PM
