Results 16 to 18 of 18
Thread: Piaggio engine rebuild torque
    Mar 2019
    Hungary
    Did u find the problem?That squeeking noice not the fuel pump u hear?Gear oil forget?
    Aug 2017
    Sweden
    Quote Originally Posted by rank1 View Post
    Hi
    Yes I found the problem, sadly no oil from the pump most likely due to air
    Also have still not managed to get oil out of it using a drill, strange I will try again.
    I did drive maybe 3 km so I don't know if the bearings and crankshaft are destroyed, atleast hope that the cylinder and pisting is okay.
    really wounder how they do this in the factory?
    2008 Aprilia SR50R Factory - My daughters current and first bike
    Mar 2019
    Hungary
    Lets start over again,shall we?
    U did bleed the oil hose from the oil tank?No air comming or stay in the hose?If yes open that little bleed screw until any air bubble is out.I tryed also using a drill and no oil moving.Strange, but when i put back in the bike it works.
    Before u start the engine add a little oil into the crankshaft.Take off that small oil hose and the adjusment lever pull to the max.Now let the engine idle.The oil should move slowly but much faster.Until the hose fill it up then connect it to the engine.Now u r safe.I just convert my purejet back from carb.After a tps and ecu reset everything works again.
  1. Sr50 with piaggio engine! :D
    By NeoGeniX in forum Scarabeo 50, SR50, Mojito 50, Rally, Fly 50
    Last Post: 03-11-2004, 07:06 PM
  2. engine rebuild cost (aus $$)
    By proddy68 in forum RS250
    Last Post: 10-22-2003, 09:21 AM
  3. Stoke/Crewe Engine rebuilds?
    By DodgeRS125SP in forum RS125 Euro-archive
    Last Post: 06-04-2003, 11:54 AM
  4. Engine Rebuild
    By Hellzone in forum RS125 Euro-archive
    Last Post: 05-29-2003, 09:16 AM
  5. Frame slider/engine bolt torque specs??? 02 Mille
    By Fusternc in forum 1000cc f.a.q
    Last Post: 07-14-2002, 10:33 AM
