Results 16 to 19 of 19
Thread: Not happy with my front brakes.
    Florida
    Quote Originally Posted by jess67 View Post
    And pull the pads and clean the calipers with Brakeclean
    DO NOT DO THIS. Not sure who gave you that idea... brake cleaner is not to be used liberally. At best spray into a lint free towel and wipe the rotor surface after the work is complete.
    Mild degreaser with a toothbrush on all the components first. Some emory pad(180 grit) for the rotors.
    Disassemble the pads from the caliper and clean & rotate the pistons. Any pins should be cleaned and polished.
    No dirt or debris should be left on the caliper. Reassemble with clean hands/gloves.
    Bleed with fresh fluid. DO NOT OVERFILL the reservoir.
    apriliaforum expert SoulDaddy's Avatar
    Oct 2004
    Vista, California, USA
    What issues does brake cleaner cause, pray tell?
    Clearwater, Fl
    Brake Cleaners have to be used with caution as they can destroy rubber/plastic and some synthetic parts plus when heated can break down into hydrogen chloride or phosgene gas which can be quite lethal. Using them to clean parts that will be heated or welded has put many folks in the hospital and killed a few too.
    https://www.popsci.com/diy/article/2...t-get-careless
    Neither the regular or non-chlorinated are safe for plastics:
    http://api.crcindustries.com/auto-se...et-pds/05084PS
    http://api.crcindustries.com/auto-se.../get-pds/05089
    Florida
    Quote Originally Posted by SoulDaddy View Post
    when used sparingly...no issues. Motorcycle brake components are not like
    automobiles.
  1. Problems with my front brakes after wheel install
    By Cipher in forum RST1000 Futura (all years)
    Last Post: 06-15-2010, 07:38 AM
  2. not happy with rhinomoto front sliders
    By DakarYM in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 09-29-2006, 10:24 AM
  3. not too happy with my helibars anymore. clip-ons?
    By velocityjunky in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 03-22-2005, 03:43 AM
  4. Replies: 6
    Last Post: 06-23-2004, 02:55 PM
  5. Hi folks, my front brakes are dragging!!!
    By tiderman998 in forum RST1000 Futura (all years)
    Last Post: 04-21-2003, 01:09 PM
