Results 1 to 9 of 9
Thread: Ditech ECU HC908 flash
    Jan 2019
    Warsaw
    Hi,
    I am looking for any internal processor (Motorola HC908) flash (program) contents for Philips Ditech/Purejet/etc ECU (may be also Peugeot/Suzuki/Gilera/etc.). Basically any ECU that looks like this https://www.apriliaforum.com/forums/...restricted-ECU is what I am looking for. Can somebody help me, please
    Jan
    apriliaforum expert Louder North's Avatar
    Nov 2011
    Ottawa, ON Canada
    Quote Originally Posted by jokl View Post
    Hi,
    Jan
    You would have to reach out to member 'TechRat' - unfortunately, he has not been active on this forum in a while.
    2007 SR 50 Ditech (Morini) 19,000 kms AND 2011 SR 50 Ditech (Piaggio) 2000 kms
    Buzzetti side stand 03/18/12
    Porter Cable water trap 06/19/12
    ECU completely derestricted ver 2.8.0 08/10/12)
    LV ZX-R 09/10/12 - repaired and painted 10/18/14
    Motul Scooter Power 2T oil
    NGK ZMR7AP spark plug, indexed, gapped to .030
    Malossi Multivar 2000 w. 7.5 gm Dr. Pulley sliders (13/06/15), Malossi Special Belt, White contrast spring @ 8000 km 11/12/12,
    Malossi X K belt, front brake pads @19,000 km 06/15/17
    8mm Mirror Riser Extender 05/12/2013
    Michelin Power Pure tires @ 9000 km 05/18/2013, replaced @19,000 07/19/2017
    HGT adjustable fuel pressure regulator 06/08/2013
    90 kph on slight down hill; 103 kph fastest ever going down hill
    Apr 2018
    USA
    Sad to see TechRat disappear with an abundance of knowledge on the SR50's electronics, but it inspired me to start my own project in dumping and reverse-engineering to allow me to program my own DiTech's. I'd be curious if anyone else might be interested in such a thing nowadays.
    Feb 2019
    Norway
    Are you aware of the previous posts at this forum on the topic?
    2006 Aprilia SR50 Factory (Piaggio Purejet C361M)
    ECU v. 2.8.0 derestricted
    Apr 2018
    USA
    I've read a few different threads on the topic, is there one in particular you're referencing?
    Apr 2018
    USA
    AFAIK techrat never (publicly) shared the ECU dump or HC908 security key. I'm waiting on some parts, but it should let me defeat the security without needing to buy the Chinese programmer that he used.
    Feb 2019
    Norway
    Quote Originally Posted by hcadam View Post
    No, just wondered where you are coming from. Unfortunately, I do not have electronic skills to supply to the project, but I know that modifying the ECU has been considered the holy grail on this forum for a long time, and there has been some posts on it, but it has ended up nowhere.
    My suggestion for a new initiative would be if somebody could sum up everything that has been said and done on the topic, and then take it from there. Create a new post with this info, and then modify the first post as progress is made, people chime in on relevant old posts, discuss what could be the possibilities for progress and start a discussion on how it could be reached etc.
    I think that's the best bet if you want to engage people to work on it. Because now, the information is kind of scattered all around, and it is way harder to ask people to work on "it" if they don't have any background information, than to start an initiative that show them what the problems and suggestions for solving them could be, and then they can be inspired to contribute.
    Aug 2019
    paris
    st12e4.txt
    Hi Jan, i've attached the full dump from a Peugeot Satelis 125 Compressor K15 (done with advanceed scooter workshop).
    I'm also interrested to get files from any manufacturer. If you have any please share as well
    File extension has been changed to txt instead of bin but it doesn't really matter
    Enjoy
  1. Aprilia SR50 Ditech ECU Question
    By ketchup007 in forum Scarabeo 50 Ditech, SR 50 Ditech, SR Factory
    Last Post: 11-17-2011, 06:06 PM
  2. Programming ditech ECU directly from PC???
    By 2ben in forum Scarabeo 50 Ditech, SR 50 Ditech, SR Factory
    Last Post: 03-15-2009, 02:33 PM
  3. Scarabeo Ditech & ECU
    By Zimo in forum Scarabeo 50 Ditech, SR 50 Ditech, SR Factory
    Last Post: 07-20-2006, 03:47 AM
  4. Ditech ECU, Gameboy
    By Team Norway in forum Scarabeo 50 Ditech, SR 50 Ditech, SR Factory
    Last Post: 09-14-2005, 07:00 PM
  5. Ditech ECU modifying
    By sr50ditech2003 in forum Scarabeo 50 Ditech, SR 50 Ditech, SR Factory
    Last Post: 02-04-2005, 04:57 PM
