Results 1 to 15 of 15
Thread: Premix or oil pump - what do you run ?
    Nov 2018
    Lanarkshire, Scotland
    Question Premix or oil pump - what do you run ?
    Iím thinking I might remove the oil pump and run premix, just wondered what you guys tend to do ?
    I like the idea of knowing exactly what my mix is and not worrying about the pump feed.
    May 2018
    Hungary
    Put up this type of cover, after you removed the pump, so the gear oil wont leak out. After this you can use Motul 800 in premix, that stuff is fikkin fukkin high quiality oil. It doesnt create a carbon layer like some others. Motul 800 has two edition, one for road race(for high rpm, over 12k) and one for cross(bellow 12k) choose the one that you would need.
    Earth
    Expensive oil ain't necessary. Exol M095 costs less than £45 per 20L drum. 32:1 ratio works. Carbon layer?.. of course.. its a two smoker ffs
    Attachment 371351
    I read it on the internet, so it must be true
    May 2018
    Hungary
    If you would care a littlebit about your bike you would know that isn't true. I saw a lot of pistons and cylinders. In the exhaust port and the top of the piston it was been completely built up by carbon. The only way was to get it down was a littlebit of sandpaper. We use these oil for racing. Motul 800 is the top-notch. No carbon at all. Which is good for better performance. And of course if you think about it the exhaust wont get full with carbon too. If you want the best for your bike choose Motul. If you don't care a shit about it then cheaper oil is a good choice too.
    May 2017
    England
    Oof, always use high quality 2 stroke oil. On 4 smokers it doesn't really matter what you use engine longevity wise, but 2 smokers always need nice fully synthetic oil for a clean burn, as kaldis said, no carbon build-up.
    Nov 2017
    Slovenia
    power1 tts by castrol or something similar...no need to go for something over 10Ä/l,because its cheaper to rebuild it every 2years then.
    apriliaforum expert twinturba's Avatar
    Apr 2004
    S.F
    I’m Injector on all street bikes and pre-mix on all track bikes.
    As far as oil, I primarily use Motul, but have started using Castrol in my daily ridden SR50 scoot.
    Jenius Biker Blog
    Current: Typhoon,Newd, TT, Max, Nastro, Rojo, Bangkok, 85 ADV
    Past: NCXD, 2X RC390ís, Madass, PW50, KTM BR 65, Aprilia BR50, 2X Aprilia RS125ís, DRD, WR250X, 7X Derbi SM's, 10x Aprilia RS50's, 2x Derbi GPR, 2x Aprilia RS250, 2X Mito, 2X NSR50R, NS50, HRC RS125, HRC RS80, YSR63 (1st 2stroke!), FZ600, KLR250(1st Bike!)
    I Need Parts!
    May 2018
    Hungary
    I have tried power1, tts. They both creating a carbon layer after like 2l's of oil. The only oil that I found is not creating it is Motul 710 and 800.
    Nov 2017
    Slovenia
    Kaldis,are your clothes having that smell of oil after riding?When you use motul...I have problem with that 2stroke smell with every oil,but didnt try motul
    May 2018
    Hungary
    If you have an MX type of pipe, your clothes will have a smell. But with the motul 800 its different. It has a very pleasant smell to it. If you have an exhaust which goes under the engine to the side of the wheel you would get any smell. Altough I fucking love the smell of Motul 800. I dont mind my clothes.
    Nov 2018
    I had a look at the oil pump this morning. It wasn’t turning round to full at the stopper when full throttle. The joy of buying second hand bikes ! It was about 1/8 of a turn away at least. I adjusted the cable to get it just about to the stopper when full throttle.
    Went to start bike and it’s peed fuel out the overflow again argghggh. Time for carb off again and if it’s dirty I’ll have to drain the tank.
    Nov 2017
    Slovenia
    Quote Originally Posted by Kaldis12 View Post
    yea starting to think that i could be because of pipe...didnt have problems with tzr and rs,only enduro...
    its.problem when u use bike for transport not for fun...ca.t rly go on drink with oil smell and parfume
    May 2018
    Hungary
    Just get used to the smell (Motul 800 has an awesome smell). I just love it. Its so unique. Its just awesome.
    Jun 2009
    Saint Petersburg, Florida
    FYI i get carbon buildup with motul on my bikes
    May 2018
    Hungary
    What type of motul? How much do you put in the fuel? With the right carburation and amount of oil in the fuel, I never ever got any carbon or just a slightly but that can be swiped off with a rag.
  1. Rear Sets... aftermarket, what do you run/ recommend?
    By ApeFactory15 in forum 2010-2019 RSV4 - All Variants
    Last Post: 04-10-2017, 09:35 AM
  2. what do you run for oil?? (Tuono)
    By Kopptl in forum General Motorcycle Talk
    Last Post: 08-13-2012, 03:43 PM
  3. oil light question(what do you think)
    By bullit in head in forum RST1000 Futura (all years)
    Last Post: 01-07-2004, 05:30 PM
  4. What gear ratio do you run?
    By steveo in forum RS50 Technical
    Last Post: 05-05-2003, 09:12 AM
