Results 1 to 12 of 12
Thread: Which engine in my 51 plate habana
    Oct 2018
    Bacup
    Smile Which engine in my 51 plate habana
    Hi guys.
    Started this thread a few weeks ago but seemed to fazzl out due to being away at the time, I have a 51 plate habana 125 vin no 204PM01001S103961 85db (A)-3750 tr/min A-1231 anyone know what engine is in this bike with this information?
    Jun 2013
    croatia
    Piaggio 125 4T AIR 2V E1
    Oct 2018
    Bacup
    Finding that ordering a replacement static variator half is a nightmare, is this model called the Beverly? Or the leader? Do any other models cross match for parts?
    Do you order for aprillia habana, or piaggio 125 4T?
    Thanks.
    ontario
    Perhaps Jog can fill you in more he’s amazing with this stuff, but until then I would just find similar engine models and try my luck.
    --- diploma for engine repair in 2012
    --- custom parts and machining --- porting and polishing
    ---derbi bullet 2006 - piaggio AC - TPR 70CC - giannelli shotV4
    ---1992 lt250r suzuki quadracer - new and improved
    --- complete 2012 wethepeople volta bmx - full sanko seamless chromoly frame/fork/handlebars
    Oct 2018
    Bacup
    Hi, yeah I gave that some thought, but the ones that might fit are around 40 ish, a bit expensive if it doesn't fit, saw some that I thought may fit but after requesting further details I was told they would not fit my engine.
    ontario
    In that case they need the diameter and a picture of center hole configuration, find a place you can get free shipping like sipscootershop and they might want to sell you some stuff.
    Slso malossi and others have websites that spit out part numbers for better kit.
    Oct 2018
    Bacup
    I measured the old one and it is just under 5 in. There are some advertised on sip scooter shop at 142 mm,by my measuring (which isn't that good) that would be too big.
    I think it is more around 127mm, what ever happened to the days when you could just quote your make and model?
    ontario
    dealers have stock parts and aftermarket shops have stuff that brings lots and lots of customers. How are either of those letting you down? Does the dealer have stock parts or not? Do aftermarket shops have more kit than they can fit on the shelf or not?
    Its a piaggio 2 valve 4 stroke. How on earth is that rare? Also all the specific models your guessing about fit have different size wheels, Perhaps you could find a model that does share your wheel size?
    Oct 2018
    Bacup
    Don't worry about it, I will sort it myself.
    Just thought someone on here may be able to help,someone has always has a simular problem,would seem not!!!
    ontario
    I did help, the dealer has all your parts. How is that not helpfull? To what degree, do you consider helpfull any way? Who else has your parts? Santaclaus? Saint Nick?
    Dec 2015
    Cambridge, MA
    https://www.oemmotorparts.com/default.asp
    look up your make and model and you can find the part number here....you can buy from them or search google for the part number...bookmark this page...you will probably need to reference it all the time
    2004 Aprilia Mojito Custom 50cc - bone stock
    2004 Aprilia Mojito Retro 50cc - 70cc Malossi BBK ported/polished, 19mm PHBG carb, VForce reed cage, oil pump delete, Polini boost bottle, TunR filter, Motoforce rear shock, Mojito 125 front fork shocks, and much much more
    2003 Vespa ET2 50cc
    2001 Triumph TT600
    Jun 2013
    croatia
    Your habana is also called aprilia mojito.
    You have the older style engine Piaggio 125 4T AIR 2V E1 and is the first generation of the "pre leader" engine installed from 1999 till middle of 2001.
    The parts you search for are easily availible if you know where to search for it.
    https://www.easyparts.nl/showdrawing/1627/25409/bla.v/0-4019-1-m412-m28817-m370-m2198-m1627-s1631-d25409/Variator-assembly.html
  1. Ahhhhh, I got a new engine in my SXV!
    By Kuneff in forum 2006-2011 Aprilia RXV, SXV, MXV 4.5/5.5 V-Twins
    Last Post: 10-31-2008, 07:50 AM
  2. Problem Which Is Doing My Head In
    By Jack Keenan in forum RS50 Technical
    Last Post: 06-21-2008, 05:22 AM
  3. *WARNING* Water in my engine oil!
    By irie in forum 2006-2011 Aprilia RXV, SXV, MXV 4.5/5.5 V-Twins
    Last Post: 06-20-2007, 12:53 PM
  4. it's gettin hot in my engine... (so take off all your fairings)
    By Speedfreak UK in forum RS125 Euro-archive
    Last Post: 03-20-2005, 11:13 AM
  5. Replies: 5
    Last Post: 10-26-2004, 07:39 AM
