Page 9 of 9 FirstFirst ... 789
Results 121 to 124 of 124
Thread: Water Pump Seals
  1. #121
    Jul 2014
    Earth
    6mm ID
    OH thankx mate.. thats why in AF1 web stated 6x10.. 10 must be OD..
  2. #122
    apriliaforum newb S Works's Avatar
    May 2015
    So Cal
    FYI, the CanAm water pump shaft and seal assembly works well. Changed everything out last week per kzmille's directions and 100 miles later it's still water tight. $32.99 at my local CanAm dealer and about $50 more at AF1 for all other seals, gaskets and washers. Thanks for all of the great information.
  3. #123
    Jul 2009
    After about 1.000 KM no leaks at all.
  4. #124
    Feb 2015
    Australia
    Removing V2 1000 waterpump seal
    Hi Guys, I have got lots of great info from this forum, like to possibly return the favour. When I removed my WP seal today, I blocked the two holes that the manual says to drive seals out with, with Al rivets, not completely engaged (just put some pressure on the wire). I then tapped for 1/4" grease nipple at the WP drain hole. Then fitted nipple and pressurised with grease- WP seal and shaft popped out easy as you'd like- no mutilation. The wires in the rivets pulled out after a tap on the top, one rivet fell out after that, the other responded to a little drilling. Perhaps could have used a grease injector type tip, instead of the thread and nipple. Anyhoo, another way to pull the waterpump out, cheers
