Results 1 to 4 of 4
Thread: Rear shock removal 2017
    nottingham
    Hey guys, I'm starting to work on my winter jobs and one of them is to have a stiffer shock spring fitted as im a fat lad.
    I'm guessing the unit needs to come upwards to remove. Has anyone attempted it yet?
    I'm 107kg without gear so i need a stiffer spring
    Dec 2015
    DePere, WI
    Yes if you plan on switching out the spring. Easy enough to do thats for sure! Just need to suspend the rear unbolt and boom it's out. Why are you thinking you need to switch it out? Did you try adjusting the preload?
    apriliaforum Junkie Kermit's Avatar
    Dec 2017
    Hexham, Northumberland, UK.
    I've weighed myself with all my gear (113 kg) and set my sag with an equivalent weight. Bricks in a backpack instead of wearing all the gear. I easily set it to 40mm front sag and 25mm rear sag (another 7 turns from stock). 2017 TV4. This may be a bit squishy for the track but I don't do track. As the man said, try extra preload first.
    I initially thought the front was a bit harsh and started winding the front preload out but after a lot of testing ended up with one extra turn of front preload from stock. The action of getting the correct sag at the rear fixed the front problems. Again, after loads of testing I found the compression and rebound damping settings were coming back to very close to stock. Setting the rear shock preload made a huge difference.
    I spent a lot of money on booze, birds and fast cars. The rest I squandered. (George Best, RIP)
    Dec 2017
    Missouri
    Sachs or Ohlins? I'm right at 106 kg and I agree with Kermit, set the rear sag and you should be good to go. My '16 Factory is handling nirvana
    2016 Factory...Cujo
    2004 Hayabusa...Tango
    2006 Honda ST1300...STella
    2003 Zuma...no nick name
  1. Rear shock removal.
    By chad951 in forum RSVR and RSVR Factory (2004-2009)
    Last Post: 08-14-2006, 08:25 PM
  2. Rear shock removal & fitting
    By TightRS in forum RS125 Euro-archive
    Last Post: 09-16-2005, 04:47 AM
  3. rear shock removal
    By rhansen162 in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 08-12-2005, 10:49 AM
  4. Rear shock removal
    By CharlieP in forum RSVR and RSVR Factory (2004-2009)
    Last Post: 03-18-2004, 04:36 PM
  5. Rear Shock Removal...
    By Nialis in forum Pegaso 650 Cube and IE
    Last Post: 02-11-2002, 07:20 PM
