Results 1 to 5 of 5
Thread: Rear grip
    New Zealand
    Rear grip
    Having an issue with rear grip on my 16 RSV4.
    I was running the wheel base quite long (at end of adjustment) and we shortened it 15 mm in the pursuit of more agility.
    Iíve had a lay off of 6 months but back in the bike with this new setting Iím noticing a big lack of rear grip at lean angle getting back on the gas.
    Wondering if this change is the contributor to this. Anyone have opinions?
    apriliaforum Member dazo's Avatar
    Jun 2016
    Minneapolis, MN
    It seems reasonable to me that a shorter wheelbase would do that.
    I recently switched from the Dunlop 200/55 to the 200/60 and a lot of other riders who made the same switch had to change the geometry of their bikes to get rear grip again with the new profile putting the bike on its nose, taking weight off the rear. Some of the changes they made were lowering the rear and raising the front. I would try those options if lengthening the wheelbase is no longer an option.
    Nov 2016
    France
    https://www.sportrider.com/more-fun-geometry
    on the ‘16 bike, we ran lengthened swinging arm plus fork extensions.
    basically we made a long and high bike, long as in wheelbase then lifted the whole bike up to get back some agility due to the higher CG
    if you are switching out rear sprockets depending on track this could influence the setup, we found all season that 41/42/43/44 rear and stayed with 15 front, this only effected wheelbase by 5mm roughly and so we did not need to play with the height via the shock length, we did this with the links,
    you can also get some duel linkage rods built up from a machine shop with +/- 0.5 variable length from stock, it’s a faster switch out than the shock’’
    Many people jack up the rear and have the bike on its nose, but extreme cases you can be scrubbing the front due to bad geometry like dazo,is saying too with the profile
    Previous bikes : AR50 - AR80 - CB250N - RD350LC - RGV250 - VT400 - TDR250 - VIRAGO 535 - RF600 - RF900 - CBR600 - GSXR750 - TL1000R - T160 TRIUMPH - R1 - PIAGGIO - R6 - RC30 - 916SPS - VFR800 - 675 DAYTONA - CBR600RR - TL1000R - YZF750 - RSV4 FACTORY.
    New Zealand
    Thanks guys for the info. This site is great.
    We ended up keeping the shorter wheelbase but dropping the rear shock length right down to 313mm, with 4mm showing on the forks.
    Not a typical setup for these bikes, but the turning is excellent and we are getting grip back. Will be interesting to see where we end up.
    Nov 2017
    california
    I have found my 16.5 that grip and steering is better with the wheel in right in the middle. Of course the rest of the geometry also plays into it. I run 116mm shock length, 2 lines on forks and 25mm offset with old shock links. Will be trying the red links in a few weeks, weather permitting
  1. Michelin City Grip tires, Front and Rear on my Sport City
    By GREY.HOUND in forum Aprilia and Piaggio 150cc-350cc
    Last Post: 04-21-2015, 05:09 AM
  2. My Shiver Dark Project: From Tail to headlamp. Part I: removing rear grips / fairing
    By Parse in forum 2008-2016 Shiver 750 / Dorsoduro 750
    Last Post: 09-21-2013, 02:36 AM
  3. Removing Rear Engine Mounting Bolts
    By rts571 in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 03-24-2013, 09:19 AM
  4. Pirelli Diablo Rear with Corsa Front?
    By MiG531 in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 07-14-2003, 07:27 PM
  5. BrakeTech full floater rear brakes for the RSV
    By micah apriliaforum com in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 07-08-2003, 11:59 PM
