Results 1 to 8 of 8
Thread: New SportCity 250 owner
    Oct 2018
    Raleigh, NC
    Greetings all. Just wanted to say hi and that I知 a new owner of a 2009 SportCity 250 with 2,200 miles. I知 looking forward to riding and learning more about the scooter and hear your stories as well as maintaining this ride.
    Wayne
    2009 Aprilia SportCity 250
    Clearwater, Fl
    Before you ride it be sure to zero set all the maintenance items. The belt, rollers, engine air filter, engine oil filter, engine oil, gear lube, brake fluid, coolant, CVT air filter, grease on the clutch shaft and tires should be changed.
    Quickest way to total an old seldom ridden bike is to ride it without zero setting all maintenance items.
    Note that if an old belt shreds it can take out the seal on the timing cover which requires a special tool too remove and replace that few shops actually own. The press tool to remove and replace the cover with the chain guides properly aligned is over $150 and the replacement cover is around $55 plus if too much belt cord gets behind the cover it can cause the timing chain to jump so you will end up at the least replacing the intake valves. Cleaning up the belt shreds the get behind the cover will require removing the valve cover to clean out all the shreds that were pulled up there by the timing chain along with remove the oil sump and oil pump cover to clean belt shreds from the pump and drive. It is a fair amount of work and you will also have to clean up all the oil that got slung around inside the CVT case. The seal on the oil sump will also need to be replaced too. Many overlook this.
    Tool - $172.07:
    http://www.af1racing.com/store/Scrip...x+AP8140729%29
    Timing Cover - $54.27
    http://www.af1racing.com/store/Scrip...Seal+%2D847116
    Oct 2018
    Raleigh, NC
    Thanks for the information. I値l do some of that. The previous owner seemed pretty well equipped. He actually replaced the Aprilia with a Bergman.
    Aug 2008
    Winnipeg, Manitoba, Canada
    Welcome to the forum. You've got a great looking ride with performance as well. Enjoy....and safe riding.
    Sp56
    apriliaforum Member Pinkscoot's Avatar
    NC
    Welcome iNov8.
    I agree on doing a maintainance reset but Rocky I didn't see any mention in his post about a shredded belt. I just changed my timing cover seal and it is not a task for a beginner.
    Italian scoots owned: 2003 Scarabeo 150, 1998 Italjet Velocifero, 2009 Vespa GTS 250, 2012 Vespa S50, 2007 BV 250, 2014 Aprilia SR50 Purejet, 1977 150 Sprint Veloce (future project) and Vespa ET2 (future project)
    Jun 2016
    Florida
    um Rocky tends to be overzealous and alarmist. Ive never seen a belt shred on a SC but this is the same Rocky that says OEM ONLY FOR 30,000 MILES mantra.
    At 2200 miles... the only things Id be checking are the airfilter, variator filter, and tires.
    Its not a bad idea to keep a belt, oil filter, or spare switch in inventory (all can be had for <$100 shipped)
    Clearwater, Fl
    Quote Originally Posted by Pinkscoot View Post
    Welcome iNov8.
    If you wait until the belt shreds then you're already exposed to timing seal damage and having to replace the cover so knowing the ramifications its best to replace the belt before that happens.
    Aug 2006
    Cleveland, Ohio, USA (now in Murrells Inlet, SC
    Don't get excited about all that maintenance and parts. I would have a few parts on hand like a belt and oil filter and maybe a filter set and gaskets. But in all the bike doesn't need a lot and if you put in synthetic oil and a good set of filters you wont have too do too much maintenance. I have the same bike and it has over 6000 miles and I just put in a malossi red air filter and iridium plug. The Dr pulley sliders I put in a few years ago. It runs very fast and will hit 90 on a straight road and get 75 mpg too.
    '67 BMW R69S-"Toots" in rehab
    '09 Silver SC250
    Previous rides:
    '04 Chinese 125
    '06 X9-500
    '08 MP3-400
    '06 BV500
    '09 Mana
  1. New Sportcity 250 Owner - New Problem/issues
    By Baldanzi in forum Aprilia and Piaggio 150cc-350cc
    Last Post: 09-15-2012, 10:01 AM
  2. New Sportcity 250 0wner, question about the ride
    By atlantaM3 in forum Aprilia and Piaggio 150cc-350cc
    Last Post: 09-24-2011, 07:45 PM
  3. So excited! New Sportcity 250 owner!
    By jas-250sc in forum Aprilia and Piaggio 150cc-350cc
    Last Post: 06-08-2009, 10:59 AM
  4. Owner's review of the Sportcity 250
    By ronnath in forum Aprilia and Piaggio 150cc-350cc
    Last Post: 08-23-2007, 07:51 AM
  5. new guy just want to say hi (sportcity 250)
    By blacksport8 in forum Aprilia and Piaggio 150cc-350cc
    Last Post: 08-12-2007, 10:53 PM
