Results 1 to 15 of 19
Thread: 2006 scarabeo 250 fuel mixture problem only getting 30 mpg
    Jun 2017
    Maryland
    My scarabeo only gets about 30 mpg. I checked just about everything that could cause poor fuel mileage. I exhaust fumes smell very rich like I'm not burning the fuel. I bought the scooter used and it's always done this so I'm not sure how it's supposed to respond when you give it full throttle but it seems to bog down a bit.
    I've attached a picture from the manual and wanted to know if the screw I need to adjust in #3.
    Also what is the automatic starter cpl.? Could that be the problem?
    Thanks for any help.
    pete
    3 is adjustment or mix screw 14 is not auto start.. but a/ By starter enriches mix on cold start.
    Jun 2017
    Maryland
    Thanks Tom. I will double check the manual but I thought it listed 14 as automatic starter CPL.
    If 14 enriches the fuel maybe it is faulty and is constantly on while I'm riding. Do you know if there is a way to test that part on the carburetor?
    I guess I can disconnect it and see if I get better fuel mileage.
    Thanks again,
    Pete
    Jun 2017
    Maryland
    This guy show you how it works. I will have to pull it off and test to see if it's working properly.
    https://www.youtube.com/watch?v=b2c3p1ntlB4
    apriliaforum Member Pinkscoot's Avatar
    NC
    I have one of these on my BV250 and it makes tuning a breeze.
    Italian scoots owned: 2003 Scarabeo 150, 1998 Italjet Velocifero, 2009 Vespa GTS 250, 2012 Vespa S50, 2007 BV 250, 2014 Aprilia SR50 Purejet, 1977 150 Sprint Veloce (future project) and Vespa ET2 (future project)
    Jun 2017
    Maryland
    Quote Originally Posted by Pinkscoot View Post
    How did it make tuning a breeze?
    Are you saying it was easy since you only have to adjust the fuel/air screw?
    BTW, I just tested the automatic starter cpl/choke and it seems to be working because it expanded when 12 volts was applied to the connections.
    I will now adjust the fuel/air screw.
    pete
    NC
    Its easy because there is no guess work, it tells you when your A/F ratio is right. No more turning screws and swapping jets back and forth. Just tune in the A/F screw for idle then up jet or down jet based on what it tells you the mixture is. My BV250 was using a lot of gas before I discovered it was leaking out of the nipple on the gas tank.
    Jun 2017
    Maryland
    What do you mean by "up jet or down jet"? I thought the only jet I would be adjusting would be the air/fuel jet.
    When I gained access to the carburetor, I noticed that the air/fuel screw was turned all the way in.
    The manual says the rpms should be 1600 +-100
    I believe the carb is running leaner with the screw all the way in so I'm not sure if adjusting is going to help with my fuel issue.
    I guess I can pull the carb, take it apart and put it in a parts washer. Maybe something is gunked up.
    Thanks,
    pete
    NC
    Pete,
    May I suggest that you read this to learn about how a Carburetor works: https://www.battlescooter.com/cv-carburetor-jetting. Though they aren't from your scooter they are exactly the same carbs.
    Jun 2017
    Maryland
    Thanks for the link. Good info. I don't think I want to put in new jets or modify my current jets but I am going to remove all the jets and clean them while I have the carb off the engine.
    I attached some pics of my carb. There is a little rubber piece that is torn. I'm not sure if that's replaceable.
    NC
    That's on the accelerator pump. Mine is torn too so I ordered new parts for mine from Dennis Kirk after searching. It said it fits all CVK carbs but I haven't had a chance to test it.
    Ok on 250 do cables pull from bottom of Carb????
    tyats a 30 mm unit compared to the beo 150 26 or so
    NC
    If I remember correctly it does pull from the bottom. Unlike the bee carb there is only one cable. Yes they are a 30mm CVK carb.
    Jun 2017
    Maryland
    I removed all the jets and cleaned the carb but I'm still running rich.
    Here a link to a video of I shot after cleaning. Not scientific but you can see the black soot on the paper towel after only a couple of seconds.
    https://drive.google.com/file/d/1qge...ew?usp=sharing
    I guess I need to replace the jets.
    Does anyone sell a rebuild kit that would include all the jets for the 2006 scarabeo 250?
    Thanks,
    pete
  1. Problem With 2006 Scarabeo 250
    By VeritechVF1S in forum Aprilia and Piaggio 150cc-350cc
    Last Post: 10-10-2018, 07:50 PM
  2. 2006 Scarabeo 250 poor fuel mileage
    By petecooke in forum Aprilia and Piaggio 150cc-350cc
    Last Post: 07-03-2017, 11:41 AM
  3. Fuel filter location on 2006 Scarabeo 250?
    By jzqrtl in forum Aprilia and Piaggio 150cc-350cc
    Last Post: 05-08-2012, 04:32 PM
  4. New 2006 Scarabeo 250 or Mojito 150???
    By Stubbie in forum Aprilia and Piaggio 150cc-350cc
    Last Post: 12-22-2007, 05:36 PM
  5. Fuel mixture problem
    By blackadder in forum Scarabeo 50, SR50, Mojito 50, Rally, Fly 50
    Last Post: 02-04-2004, 11:22 AM
