Results 1 to 7 of 7
Thread: Piaggio BV 200. One day good one bad
    Sep 2018
    CA
    I have a 2003 BV 200 the vacuums fuel pump was leaking and replaced. Also replaced lines with 1/4 inch and cleaned carb. Replaced vent foam. New idle jet and valve adjustment. I moved slide needle from very lean top of the needle to less lean bottom and there is no comparison on the performance as it bogs under throttle when lean. Problem is fuel screw open to 2 and 3/4 turns and yet one day it won’t run and am not sure why. Automatic choke is extending as she warms up. Could it be happening too soon or bad connection? The fuel filter is. It stock and there is space in the filter. Fuel does not poor out when fuel line removed from carb to check flow. Thought maybe Intake manifold perhaps has some small leak that shows itself more when cold and fuel has not built up in the line. Was going to replace. After market Mallosi air filter. Bike runs as if still not getting gas. Help, driving me little crazy.
    Aug 2017
    Napa CA
    did you put the lines to fuel pump on the correct outlets?
    2016 Piaggio BV 350
    2008 Yamaha WR 250
    Feb 2005
    NorthernVA-EastTN-SWFlorida
    You might try posting on Modernvespa.com as this is a common engine on some Vespa scooters.
    Vernon
    Sep 2018
    CA
    I did, as the line in has an arrow for the flow and the vacuum has a P for the pulse. The bike also does run but inconsistently.
    Iv bottle Gravity feed it . wen this is done are all problems gone? till bottle runs out ? if so youve a fuel or fuel volume issue . try a keihin ruckus np50 elec pump about 14 bux see if that clears up the mess it did on my scarabeo 150
    Sep 2018
    CA
    Could it be a compression issue? It does fine when sitting and cold then when riding it suddenly bogs. Thanks for the help!!
    Jun 2013
    croatia
    take down the fuel and the vacuum hose
    suck on the vacuum hose, and hold it, if it looses vacuum its up for a replacement (use only the original diamether hose)
    if the fuel dosnt come out when you suck undo the tank cap, if it then starts to poore fuel then you have a tank ventilation problem (almost always clogged breather system)
    also when you see the fuel going fill up the carburetor start it up and see if runs ok. if it does you will need to replace some faulty part of the fuel system.
    tie all hoses with zipties especialy the vacuum line so you dont loose the vacuum.
    Also use only original air filter and check the idle jet for clogging.
    It can clog then you will experiance a lean running condition.
  1. one bad ass kid...
    By jay dub in forum 2006-2011 Aprilia RXV, SXV, MXV 4.5/5.5 V-Twins
    Last Post: 09-05-2010, 02:44 AM
  2. Any Piaggio owners try one of these yet?
    By High Gain Tuning in forum Scarabeo 50 Ditech, SR 50 Ditech, SR Factory
    Last Post: 10-11-2009, 09:44 PM
  3. Good and bad day on the Falco.
    By gravel in forum SL1000 Falco Forum (all years)
    Last Post: 04-25-2007, 02:35 PM
  4. One Bad Tuono! AF1 Factory Style
    By Jon / AF1 Racing in forum Tuono 1000 R and Tuono Factory (2006-2010)
    Last Post: 09-12-2006, 08:38 PM
  5. Did anyone consider the Piaggio BV 200?
    By Bertman in forum Aprilia and Piaggio 500cc
    Last Post: 04-17-2003, 10:06 AM
