Results 1 to 14 of 14
Thread: Motorcycle electrical connectors & terminals
    apriliaforum expert craigo298er's Avatar
    Jun 2012
    843>440
    Of course I find what I need after I Frankenstein things together on my Grom...
    http://www.cycleterminal.com/
    http://www.cycleterminal.com/crimp-tools.html they even have the correct crimps
    Sealed and Non-Sealed Connectors
    We have Vintage and modern Sport-bike Motorcycle Wiring Harness electrical Connectors, these Connectors are purchase directly from the manufacturer, And in many cases the OEM Supplier, The terminals and connectors are superior quality. Most are Manufactured in the USA, Japan, or Europe.
    Bullet Connectors, Yazaki, Sumitomo, JAE, Hitachi, 6.3mm - .250, 2.8mm - .110, 2.3mm - .090, Connector Sets with terminals, Mini Relay Connectors, Voltage Regulator-Rectifier Connector for Honda, H4 Headlight connector and couplers.
    Motorcycle Open Barrel Crimp Tools, Wire Stripers, and Extraction Removal Tool for Molex, Amp,Yazaki, Sumitomo, Amphenol - Deutsch, JAE terminals, By Pressmaster, Eclipse, Lisle, Channellock, Amphenol, Delphi.
    Jul 2009
    AUS
    Yes after starting to solder and dodge the suzi resto connections i got me some packs of connectors ,the best thing ever was the plyers suited to the connectors best money i ever spent .Then i grabbed some nice strippers the wire variety .
    Sep 2018
    SoCal USA
    I like to use components made for the marine industry, available at West Marine, near my house. Very high quality, made to withstand saltwater.
    Sep 2014
    Portland, Oregon
    I would recommend Cycle-terminal as a great source for motorcycle terminals and connectors. Joe is a very helpful guy.
    Jan 2017
    Texas
    Thanks for posting that.
    apriliaforum expert LEDAero's Avatar
    Sep 2015
    Aja - When all my dime dancin' is through
    So many good connectors available now.
    I use these.
    And these
    Also always use dielectric grease in the pins. I use one with a fluorescent dye trace, so it’s easy to spot if there is water ingress.
    For when you can’t slip some heat shrink over a cable/connector, I always use silicone self-amalgamating tape. Turns into a solid piece of rubber once installed, as good as a cast grommet or fitting. 3M from choice, but there’s a ton of makers.
    Here in the tropics heat, dust and humidity are a nightmare for connections. My wife arrived home on Saturday with a full Christmas tree on the dash of her Toyota. A quick disconnect, squirt with contact cleaner, a brush of dielectric and plug back together and they all went away - apart from the abs light, but for that I need to take the wheels off, pull and clean the rotation sensors. Brake dust, dirt and damp make a crust that the hall-effect just can’t read through.
    Welcome to the monsoon season!
    “The sad thing is you will never be freer or more yourself than when it’s five in the morning, the sun’s about to rise and you’re out of your mind” Nick
    “Trump? He’s as stupid as a man who bought his stupid at a two for one sale.” Nancy.
    Sep 2015
    Quote Originally Posted by Rubino View Post
    West Marine stuff is the shizz.
    Sep 2018
    SoCal USA
    Quote Originally Posted by LEDAero View Post
    I am not sure what you mean by that.
    Sep 2015
    It’s very good. Best boat epoxies and sealants I’ve used.
    https://www.westmarine.com/resin-resin-hardener
    Jan 2007
    Hammond, Indiana - USA
    Anyone know where to source 2.3mm round male and female connectors, as used on the Aprilia RSV Mille?
    Found them at Digikey.
    They are Molex .093 series.
    39-00-0296
    03-09-1011
    03-09-2011
    Hoosier, not hoser.
    2016 Tuono 1100 Factory
    1983 Yamaha XJ650LK Seca Turbo
    2006 Yamaha FJR1300AE
    apriliaforum expert JCG's Avatar
    Jun 2006
    Lexington,KY
    I also use this place>>> http://www.vintageconnections.com/
    Chris
    What kind of bike is that?
    It's an Aprilia!!!
    Who makes them?
    .......... lets go of clutch lever.
    Ireland
    Quote Originally Posted by craigo298er View Post
    Of course I find what8 I need after I Frankenstein things together on my Grom...
    Eww leccy porn..
    Particularly like the look of that splicing crimp.
    Delphi my fave. Use the 280 and apex range. Soul satisfying putting these together, love the way the closure mech causes the terminal to seat with a muted "ting!"
    Brum Brum
    Ireland
    I use these.
    And these
    Top ones are intresting. I see they are indexed push fit but others appear treaded. Does turning the threaded element twist the wires, hopefully not? How are the wires sealed going into the back of the connector?
    Brother led i bought the same yello n black kit as the middle pic offa amazon. I'll use em on low power connections indicators etc on mates bikes who usually utilise chewing gum and its foil wrapper to bodge electrics with. Better than twist and tape but the terminals are super flimsy and wouldn't let them near a charging circuit say. Still n all good to have.
    Brum Brum
    Mar 2018
    California
    Andseron Power Pole connectors.
  1. Capo Electrical Connectors and terminals
    By brmbrm in forum ETV1000 CapoNord (2001-2007)
    Last Post: 08-10-2017, 01:06 PM
  2. Electrical connectors, like the mirror/turn signal plugs?
    By BHW in forum RST1000 Futura (all years)
    Last Post: 09-14-2007, 08:36 PM
  3. Fried headlight electrical connector!
    By RichL025 in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 03-28-2006, 10:30 PM
  4. What is this electrical connector?
    By Red Label Moto in forum RS50 Technical
    Last Post: 02-12-2006, 01:06 PM
  5. Futura Charging/Electrical Connector Problem
    By RGFutura in forum RST1000 Futura (all years)
    Last Post: 11-14-2005, 10:12 AM
