Results 46 to 51 of 51
Thread: Big end banging
  1. #46
    Oct 2018
    athens
    Thank you. I have model 200 but nobody seems to ship to Greece (I have asked some). There are no custom or other taxes within Europe.
    Today I measured the diameter of the crankshaft. It is 31,95-32,00 when minimum in manual is 32,01mm.
  2. #47
    Clearwater, Fl
    Quote Originally Posted by aware View Post
    So if you try to dress it/polish off the scoring then it will unfortunately be well below tolerance and not just marginal. Sorry I don't know a better source of parts for you.
    I wish you luck on finding a good shop who can sleeve your crank or possibly source undersized bearings and turn down the crankshaft to match them.
  3. #48
    Oct 2018
    athens
    Spoke to special shop today, they can't access the side with wear because of the sprockets. The tool can't reach.
    Today bought a second hand crankshaft in good condition for 180 euros.
  4. #49
    Clearwater, Fl
    Glad you found a reasonable solution. Now be very careful to ensure that all the oil passages are clean and open.
    Some of those engines have some very small orifices in the crankcase that spray a mist of oil in some locations and will result in hot spots and extreme wear if they become clogged.
  5. #50
    Oct 2018
    athens
    Thank you.
    The oil passages are difficult for me to to follow.
    For example, the oil holes at the bearing shells seems to be dead-end. Can it be?
  6. #51
    Clearwater, Fl
    Thank you.
    Likely they intersect at a sharp angle with another passage to get to the main feed. A rubber tipped blow gun is very handy for ensuring that you got them all cleaned out. G, B and E guitar strings used cautiously can also be helpful.
    Be very careful where you use sealant too so you don't clog anything when you put it all back together.
  1. Flywheel nut /// Big End bearing
    By aprilakias in forum RS125 Euro-archive
    Last Post: 11-30-2006, 05:35 PM
  2. Big end bearing
    By joer1989 in forum RS125 Euro-archive
    Last Post: 10-08-2006, 08:46 AM
  3. big end bearings
    By philhansen in forum RS125 Euro-archive
    Last Post: 03-30-2005, 12:29 PM
  4. Big end/crank bearing removal
    By GavinR96 in forum RS125 Euro-archive
    Last Post: 02-20-2005, 09:19 PM
  5. big end
    By JakeRS125 in forum RS125 Euro-archive
    Last Post: 05-19-2004, 10:12 AM
