Results 1 to 2 of 2
Thread: Dead dashboard & the usual fixes did not work
    apriliaforum prov-nov joost.bijl's Avatar
    Jun 2008
    Delft, NL
    Hi,
    My dashboard died and thanks to this forum i got a few good pointers on where to start fixing it. Unfortunately it does not work yet.
    I have a 2002 Caponord with 90k on the clock.
    What happened
    The first time the dashboard went dead was 3 months and 3000km ago. After a very small break i started and the dashboard was dead. I drove off and after 2 minutes or so the dashboard started up as it would normally at turning the ignition key.
    Then the symptoms did not show for 2 months.
    When on a roadtrip through the Balkans (yay TET!) the same thing happened again sporadically at first. Sometimes it would boot 'delayed', sometimes it would be normal, sometimes it would not boot at all. After a few days the dashboard never came back to life.
    What did i do
    I replaced the three capacitors, although they did not look faulty. When reading Karls moto-abruzzo website this seems a logical thing to do though.
    I also made the via that meanstrk points out in his post on the subject. This via was indeed not working.
Name:	after fix - front.jpg
Name:	after fix - back.jpg
    Current symptoms
    The dashboard does not do anything, except the leds for kickstand, oil pressure, efi and neutral. With both the contact off and on, the efi light glows faintly:
Name:	showing faint efi light with ignition on.jpg
    ^^ Here the ignition is on
Name:	showing faint efi light with ignition off.jpg
    ^^ Here the ignition is off, note the faint efi light
    (pics are when i added a via myself (i'm a bad solderer) and the capacitors were not changed yet. The symptoms are the same)
    Now what
    I'm not really sure what to do next. One thing is that i'll trace the circuits to find other bad via's (um, i'll ask people way more skilled than me to help me do this.. i mean). Is there anything else you can suggest, or should i cave and ask someone to have a go at it? (moto-abruzzo or beasthonda i guess?)
    apriliaforum expert haga lout's Avatar
    Jun 2009
    oldham uk and soon gibraltar
    Quote Originally Posted by joost.bijl View Post
    Hi,
    What happened
    What did i do
    Current symptoms
    Now what
    Andy ( beasthonda ) is not doing repaired now as he has changed jobs think Carl is doing them contact him on his web page
  1. Tilt switch did not work
    By MrDull in forum 2008-2016 Shiver 750 / Dorsoduro 750
    Last Post: 07-15-2013, 12:17 PM
  2. Beo finally went down and . . . the world did not end!
    By Jenniferal in forum Aprilia and Piaggio 500cc
    Last Post: 09-08-2007, 11:26 AM
  3. Charging problem, not the usual one!
    By BoraYurtoren in forum ETV1000 CapoNord (2001-2007)
    Last Post: 08-16-2007, 05:44 AM
  4. Not the Usual Engine Ice/Water Wetter Question
    By hank in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 03-22-2007, 02:36 PM
  5. NOT the usual chip question
    By fblader1 in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 03-18-2006, 04:04 PM
