Results 1 to 5 of 5
Thread: Voltage Regulator
    Aug 2013
    United States
    Voltage Regulator
    Aprilia Scarabeo 200. Battery slowly dies after charging. When I jump start it, the instrument panel flashes on and off. Like what it would do when you first turn the key on. Engine keeps running. But instruments keep flashing like they do when you first turn the key on and it does the self test. Battery terminals are tight. Could a bad voltage regulator be causing this?
    Aug 2008
    Winnipeg, Manitoba, Canada
    How old is the battery? That's the easiest to check and replace if necessary.
    Sp56
    Aug 2013
    United States
    The battery is brand new. That was my first thought as to what it might be.
    Volt meter across terminals and above idle what ya see? 14.5?
    Aug 2008
    The 200 has a built in voltmeter. What does it show at idle and also when riding. Mine shows 14.4v when riding and 12.5-13 at idle.
    Sp56
  1. Voltage regulator (ooh it's hot hot hot)
    By Matt Jarrett in forum ETV1000 CapoNord (2001-2007)
    Last Post: 06-30-2005, 08:18 AM
  2. Stu-O voltage regulator question
    By Caponerd in forum ETV1000 CapoNord (2001-2007)
    Last Post: 09-23-2004, 02:18 PM
  3. Voltage regulator......not
    By JoBlue in forum Pegaso 650 Cube and IE
    Last Post: 10-04-2003, 03:28 PM
  4. VOLTAGE REGULATOR HELP
    By fatboyz in forum RS125 Euro-archive
    Last Post: 06-05-2003, 02:46 PM
  5. location of voltage regulator
    By handyman65 in forum Aprilia and Piaggio 500cc
    Last Post: 03-28-2003, 12:13 AM
