Results 1 to 14 of 14
Thread: Belt Slapping
    Aug 2018
    San Antonio, Texas 78226
    Unhappy Belt Slapping
    I have a 2009 Aprilia 200 Scarabeo that has belt slapping. The slapping comes from the belt slapping on the roller and makes noise. I removed the roller and the noise stopped. I put the roller back because it's there for a purpose. My question to you out there is how to correct this to stop the noise? Do I buy a new belt, remove the roller or etc.........? Thanks, Jesse
    Aug 2008
    Winnipeg, Manitoba, Canada
    I have an '08 Beo 200. I have never experienced what you describe, but does the roller move freely? Is your belt an OEM belt. Is it a recent install or how old/many miles are there on it? More info could help with a solution.
    Sp56
    Aug 2018
    1700 miles, roller moves freely and correct belt size. I checked with Aprilia parts in Austin. Part# 856026 Thanks
    try a belt thats like 20 mm shorter etc i do this on the rotax and get better belt performances running up n down the sheaves its noticeable and belts wear better on the rotax we use Gates belt @ like 19 bux Aramid design
    Aug 2018
    Thanks TomD
    Aug 2008
    OK. Has it been making noise since 0 miles? How does it run/ride on the road?
    The variator and rear pulley, as they change the ratio during acceleration do cause the belt to move somewhat but not enough to make a slapping noise. When you run it with the trans cover off and safely on its stand does the belt move fully?
    1700 is very low mileage for an'09. Perhaps the variator isn't moving freely due to a stuck rollers or slider blocks.
    What have you had apart so far?
    Sp56
    Aug 2018
    The belt slaps only when idled and makes noise. Once I accelerate the noise stops. I bought the bike used and looks very good. I'm the second owner. Maybe I'll just leave it alone????
    Aug 2008
    Maybe mine slaps and my hearing just isn't as good as yours. At idle the belt doesn't flex much so it shouldn't be slapping at all. If it rides well otherwise.......
    Being as old as it is a service is warranted even with the low miles.
    Safe riding.
    Sp56
    Aug 2018
    Thank you all very much. The bike works very well on the road. I have driven it up to 80 mph.
    thats what that idler is for i got slap on a few knocked 15 or so mm off belt diameter slap pretty much gone tighter belt performance on scoot performance sites they discuss this stuff
    Clearwater, Fl
    Quote Originally Posted by JesseD View Post
    If thats the original belt then your on borrowed time. Its old, hard and has taken a set from sitting so long in one position.
    If you have not already done so you really need to ZeroSet all the maintenance items such as belts, rollers, clutch grease, oil, gear lube, filters, brake flush, coolant flush, etc. Also be sure that the tires are less than 3 years old and not the originals as a tread separation at 80 mph is not by any means fun.
    Aug 2018
    Thank You all very much. Jesse
    Jun 2013
    croatia
    if it still slaps the case check the belt for streching and wearmarks and check the contrast spring for wear
    when they go they often cant stretch the belt fully and the belt gets loose and slaps on the casing
    also variator sliders when they are worn produce a ratteling noice
    Aug 2018
    Thanks, all. Jesse
  1. V belt slapping noise
    By Rob in Denver in forum Aprilia and Piaggio 500cc
    Last Post: 05-19-2008, 04:47 PM
  2. Kevlar Belt
    By Amateur in forum Scarabeo 50, SR50, Mojito 50, Rally, Fly 50
    Last Post: 07-11-2003, 05:10 PM
  3. tank slapping
    By project mini in forum RS125 Euro-archive
    Last Post: 06-05-2003, 02:56 PM
  4. Belt rubbing? interferance?
    By mawayda in forum Aprilia and Piaggio 500cc
    Last Post: 03-18-2003, 09:56 PM
  5. Atlantic drive belt
    By Swamprat in forum Aprilia and Piaggio 500cc
    Last Post: 08-23-2002, 09:41 AM
