Thread: What Should i pack my air box with?
    apriliaforum newb Vike's Avatar
    Sep 2018
    Sweden
    Hmmm? its leaky.
    Everything will always find way a to fucking brake...
    apriliaforum Junkie THE BROWN NOTE's Avatar
    UK
    Spray-on filter oil is the least runny type. Chainsaw bar oil is cheap and tacky, but the filter needs wringing out properly.
    apriliaforum expert Rj_666's Avatar
    May 2013
    Seattle, wa USA
    Not sure what you mean - do you mean what sort of filter element you should use, do you mean what sort of 'seal' should you use between the top and the bottom of the air box ?
    I once bought a bike, and pulled the tank / checked the airbox, only to find mice were nesting in the airbox. You could probably 'pack the airbox' with small rodents pretty easily .....
    Stock parts are pretty readily available (at least these parts) I'm in the US, and get filter element / airbox seal from the hosts of our forums, AF1racing
    =My Iron Maiden=
    1999 Aprilia RS50
    Doppler endo crank
    Barnett Clutch
    DellOrto PHBG 21 mm AS
    W8 needle - n2, 103 MJ, 262-AU, 60 idle, 42 pilot, #30 slide
    Pre-mixing Trick 101 octane / Motul 800 @38:1
    Top Performance 8 petal Reed Block w/ Stuffer
    Top Performance TPR aluminum, 50 mm piston, 1 ring
    Yasuni R2 Carbon Exhaust
    13/43 final gearing
    AF1 spring upgrade & 'Martin77 / Mattology' preload adjusters
    DNM 'MT-Bag' 3 way adjustable rear shock absorber
    Mitas MC50 tyres
    Brembo RCS 14 front master / NG rotors / Ferodo pads
  1. A lot of oil in my air box what's causing it
    By bearking in forum ETV1000 CapoNord (2001-2007)
    Last Post: 05-15-2016, 09:37 AM
  2. SXV 550 have clean oil filling up my air box. :(
    By civichatch in forum 2006-2011 Aprilia RXV, SXV, MXV 4.5/5.5 V-Twins
    Last Post: 01-05-2013, 11:43 AM
  3. New sxv 5.5 owner here. Why does my air box hose keep filling up?
    By jasen b in forum 2006-2011 Aprilia RXV, SXV, MXV 4.5/5.5 V-Twins
    Last Post: 06-02-2011, 09:12 PM
  4. 01 air box with 57mm TB's and a few other questions
    By jibjabhater in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 03-07-2008, 10:31 AM
  5. Oil in my air box?
    By bayarearider in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 10-14-2007, 11:51 PM
