Results 1 to 12 of 12
Thread: Aluminum Crush Washers for Oil Changes
    apriliaforum Member tgodon13's Avatar
    Sep 2017
    Neshanic Station, NJ
    I went in search of an alternative to the rather pricey aluminium crush washers that are needed for our frequent SXV oil changes....
    Check out eEuroparts.com...I got 24 of them for $10.75 including shipping. They are only 24 cents each instead of paying $2.85 each.
    https://www.eeuroparts.com/Parts/539...RoC3iIQAvD_BwE
Name:	Crush Washers.jpg
    _______________________________
    2008 Aprilia SXV 450
    2015 VW GTI 2 door SE 6MT
    Feb 2009
    Tri-Cities, Washington
    I have switched to copper washers on most of my drain and pressure switches. They can be reused many times and aren’t subject to the galling that the aluminum washers seem to get when torquing.
    Sep 2017
    Quote Originally Posted by SXVINWA View Post
    Good info. I'll do it after the 8 oil changes I have enough for!!!!!
    apriliaforum expert Britt's Avatar
    Westmont, IL. USA
    Good info!
    2009 Aprilia RXV 450
    2014 Yamaha Super Tenere ES
    Previous Aprilia's: 2002 Caponord : 2001 Falco
    apriliaforum Junkie MaK's Avatar
    Jun 2010
    Germany
    You can get a set of 100 pieces of washer (alloy or copper) from e.ay etc., like the ones in the picture above with the same diameter if you look in the car section etc. . Cheap alternative.
    I got mine (copper) ~ 2 years ago from the big auction platform and there are still > than 2/3 of them left. They are very durable.
    apriliaforum expert daws's Avatar
    May 2009
    Sunshine Coast, Aus
    I use a car crush washer of the same size, the package states that they fit BMW, Mercedes, Nissan and various models of Ford Falcon I got a big pack for next to nothing from my local auto suppliers.
    #314 - Aprilia SMXV450
    Snap Fitness Caloundra - www.snapfitness.com.au/caloundra
    Übermoto Custom Graphics - www.uber-moto.com
    M2R helmets - www.made2race.com.au/
    Duke Racing Represent!
    apriliaforum Junkie freedomgli's Avatar
    Sep 2009
    +1 buy in bulk for $10 from Amazon or eBay. I prefer copper, but to each his own.
    Aug 2004
    Philadelphia, US
    Copper is nice to work with. Just be careful with the reuse of copper sealing washers, they work harden pretty quickly (first or second use) and then don't crush and seal as well as they did originally. One can heat a copper washer to a very faint, subtle orange glow (as seen under low light) and then let it cool naturally (don't quench). That process will soften it up again for reuse. I've done this with good results on diesel injector sealing washers that have to hold fairly high peak cylinder pressures.
    Feb 2009
    I actually find that quenching leaves the copper super soft. Copper does not harden the same way as steel.
    Aug 2004
    Philadelphia, US
    Right, very good point. Ferrous metals need to be quenched as part of the annealing process but copper and brass anneal well either way; let them cool slowly or quench in water or oil. If one cares about the look of the copper, Borax can be added to the quench water and it will take care of a lot of the dark / black oxides.
    apriliaforum Junkie rollracer's Avatar
    Feb 2019
    canada
    any idea about the exact size?
    in the first post i'm reading 12X18X15mm thick?
    would order a bunch since bike's drain plugs are pretty much one size fit all....
    are those would be correct? i see they're 12X17X1.5mm thick.....instead of 12X18X15......
    https://www.amazon.ca/Copper-Washer-.../dp/B01FTLMLO2
  1. 9 OEM Oil Filters & Crush Washers for Sale
    By DocJ in forum 2012-2019 Tuono V4 - All Variants
    Last Post: 10-17-2015, 07:44 PM
  2. 9 OEM Oil Filters & Crush Washers for Sale
    By DocJ in forum Aprilia Parts and Accessories for Sale / Wanted
  3. Where to get crush washers for oil plug?
    By dleasman in forum Aprilia and Piaggio 500cc
    Last Post: 05-18-2012, 02:52 PM
  4. crush washer for oil change
    By zvez in forum RSV Tuono, Tuono R, Tuono Racing, and Tuono Factory (2002-2005)
    Last Post: 03-12-2006, 08:50 AM
  5. Time for Oil change. Change it now . . or the Spring??
    By PNorris in forum RSVR and RSVR Factory (2004-2009)
    Last Post: 10-26-2004, 02:05 PM
