Results 1 to 8 of 8
Thread: Where to get new MAPS in South Africa
    Aug 2018
    Cape Town
    Hi everyone,
    New to the forum and I have a stock 1200 DD that I got 2 months ago. The fueling is terrible, and throttling in the lower gears is terrible. I'm pretty sure it still has the original mapping. I live in Cape Town and I don't know of anyone who can tune Aprilias.
    Any advice from anyone?
    Also, where is the best place to go for a service? (Please don't say Cayenne)
    Apr 2005
    Cape Town
    I am working on remaps for the 1200.
    TXB Navigator, XV tuner and Tune Ecu.
    Feb 2019
    Johannesburg, South Africa
    Sorry to hijack - Stretch - Any luck with the remaps? what all is involved?
    Thanks.
    Jul 2017
    South Africa
    i luckily had my remap done wen Cayenne was still open
    Don t know of any place that will do it
    But glad to have some more DD owners in sa
    Feb 2019
    haha. Lucky you!
    Im in the process of bringing in a cable - should be able to use Tune ECU then! Will use a local dyno and play with the map a bit
    I do think I have some issues with the Cam Chain Intermediate gear though! I have a HORRIBLE tick!
    Jul 2017
    South Africa
    joint the club it sounds like a bad shim but its not
    my bike has 45k on and i have made peas the sound has not gotten louder over time so ja
    Jan 2016
    Vancouver, BC, Canada
    Send your ECU to Gabro. Info on this forum.
    Feb 2019
    Hi gents,
    So with TuneECU's help, Ive been able to adjust fueling/timing/throttle maps on our SA bikes.
    Ill be going to a dyno sometime soon to play properly with these numbers and try get the best mix between power / fuel economy.
    For now, Ive applied the fueling and timing as found on the Akro Full Power map received from DanielDD1200 . Thanks DAN!
    If anyone in Johannesburg needs assistance - i have the cable, so you more than welcome to pop by.
    Cheers.
  1. Frame plastic protectors pealing off - where to get new ones?
    By razteo in forum 2008-2016 Shiver 750 / Dorsoduro 750
    Last Post: 10-14-2013, 02:58 PM
  2. think im in need of a new sprag (where to get)
    By belfast blaster in forum 2006-2011 Aprilia RXV, SXV, MXV 4.5/5.5 V-Twins
    Last Post: 05-12-2013, 03:32 PM
  3. where to get slick tire in Melbourne
    By Troy0907 in forum RS250
    Last Post: 09-21-2010, 11:28 PM
  4. Where to get Valves done in COLumbus ohio
    By rocketboy21 in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 08-04-2005, 11:54 AM
  5. Anyone has or knows where to get clutch spring in US?
    By fishnick in forum Scarabeo 50 Ditech, SR 50 Ditech, SR Factory
    Last Post: 07-28-2005, 10:06 PM
