Thread: How to replace pressed-in pilot jets?
    Oct 2010
    Bostonish, MA
    I see lots of posts mentioning the need to do this but none actually describing how to do it. Is it possible to do with regular garage tools? I have rebuilt many carbs but they've all been screw-in jets.
    thanks,
    jim
    Sep 2015
    Fayence
    Jim,
    I'm late to this stomping party, but here's how I've done it in the past...
    Drive a self-tapping screw into the hole in the jet, then pull it our with a pair of pliers. Crude, it destroys your jet, but it's completely effective. Before you go there though, consider drilling the jet to a larger size (if that's your target of removing in in the first place), and/or be sure you have replacement jets before you destroy your originals.
    Cheers... Paul
    Oct 2010
    Bostonish, MA
    Thanks Paul. I've since been told by the previous owner that there should be bigger jets already in there. As I was able to clear them with a heavy dose of Sea Foam I'll leave them for now and hope the PO is right.
    jim
    Quote Originally Posted by tinwelp View Post
    Jim,
    Cheers... Paul
  1. How to Replace the In Tank Fuel Line
    By JulioB in forum Aprilia and Piaggio 500cc
    Last Post: 11-10-2018, 06:53 PM
  2. How to replace the belt -- as in, get the new one on ?
    By joesmoe in forum Aprilia and Piaggio 500cc
    Last Post: 11-06-2011, 05:31 PM
  3. 2.8.0 to the early 02 ditech? and how to gameboy tuning in detail?
    By Ditech_ in forum Scarabeo 50 Ditech, SR 50 Ditech, SR Factory
    Last Post: 06-12-2011, 03:23 PM
  4. How to replace horn in A500
    By adamblock in forum Aprilia and Piaggio 500cc
    Last Post: 01-17-2006, 09:40 PM
  5. how to remove scratches in Futura gas tank
    By wolfemanct in forum RST1000 Futura (all years)
    Last Post: 06-12-2003, 09:19 AM
