Results 1 to 7 of 7
Thread: Vacuum hoses
    Apr 2009
    Vacuum hoses
    While Iím waiting for the TPS to arrive from Italy, Iím going to change out all the vacuum lines.
    My question is what sizes and length do I need? Also, should I change the fittings?
    Oct 2004
    San Marcos, California, USA
    I can't imagine that anyone is going to give you a detailed answer to those questions, so short of ordering everything from AF1, if even possible, just take copious photographs of existing line routing/installation and even tag the lines with ID info, then pull them and take all the pieces to a GOOD auto parts store for duplication. Then pay LOTS of attention when installing the new goodies.
    On second thought, there's only a couple sizes of the tubing used, so just go buy a couple feet of each and cut/replace sequentially in lieu of yanking everything off.
    Yes, get the unions/connectors, too.
    Dogs are the best people.
    Oct 2013
    United States
    I replaced all of my OEM vacuum tubing with platinum cured silicone tubing (stays shiny even when old) off of Amazon:
    https://smile.amazon.com/Platinum-Cu...ilicone+Vacuum
    I just replaced each piece by pulling a single one off individually, cutting the proper length, and replacing it, with new connectors as I went.
    I also replaced all of the oil lines and IAC lines with 9.5mm and 13mm Flourosilicone hoses from AutoSiliconeHoses (ASH):
    http://www.autosiliconehoses.com/sil...oro-hoses.html
    Aug 2009
    Portland, Oregon
    Did you order the fluorosilicone lines from the UK? Or were you able to find a US distributor?
    Would you be willing to sell your leftover tubing, or is there not enough to do a second bike?
    This is the sort of project I like to take care of when I have things apart anyway, but it's like picking a thread on a sweater...once you start, you notice those rusty bolts over there that you could replace with stainless, and before you know it, you have a jigsaw puzzle on your garage floor!
    Oct 2013
    United States
    I did order them from the UK. I can look if I have enough for a second bike.
    Mar 2012
    On the road between ID & OR
    spacewrench,
    I'll likely do mine this winter, and am pretty close to you. We could split resources if infrasoundxp doesn't have enough.
    JD
    Futura
    Bunch of dirtbikes
    Oct 2013
    United States
    I have enough 11mm left (used for large oil line) for another 2 bikes probably, but not enough 9.5mm. Only have enough 9.5mm for one of the oil lines on the bottom of one bike and not for the IAC lines.
  1. Vacuum Hose Pictures (that would effect low idle)
    By Ozman2downs in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 09-08-2008, 06:15 PM
  2. Found loose vacuum hose
    By Anders J. in forum RSVR and RSVR Factory (2004-2009)
    Last Post: 08-10-2007, 12:18 PM
  3. Vacuum hoses. What goes where?
    By Bart2207 in forum RSVR and RSVR Factory (2004-2009)
    Last Post: 02-12-2007, 09:24 AM
  4. Vacuum hose cracking
    By rblue02 in forum RST1000 Futura (all years)
    Last Post: 07-17-2006, 01:30 PM
  5. Vacuum "hosed"
    By BigGlen in forum RSV Tuono, Tuono R, Tuono Racing, and Tuono Factory (2002-2005)
    Last Post: 09-13-2003, 04:20 AM
