Results 16 to 30 of 38
Thread: Trying to send a private message to William the Third?
    The Anal Intruder William the Third's Avatar
    Oct 2003
    Asheville, NC
    Sent.
    #1 Forum Loser
    1973 Harley-Davidson Aermacchi Z-90 - Restoration project
    Oct 2018
    Norway
    Hello William, could you send me an email? I've got a ecu needing a tune up.
    Cheers
    Anders
    Mar 2019
    Ontario
    Quote Originally Posted by William the Third View Post
    So I've been getting quite a few friend request recently, and I suspect it may be from people trying to contact me about derestricting their ECU. If you have fewer than 10 post on the forum you can't send/receive private messages. If you need to contact me post a message here and I can send you an email at the email address you used to register, so no need to post any contact information publicly.
    Can you email me in regards to ECU ? Thanks
    Oct 2003
    Asheville, NC
    Quote Originally Posted by ScarabeoOntario View Post
    I apologize for the late response, been a bit busy. I just sent you an email.
    #1 Forum Loser
    Mar 2019
    Vancouver, BC
    Sign me up too Billy. How do I tell what version is in there now? Thanks in advance!
    Oct 2003
    Asheville, NC
    Quote Originally Posted by 09SR50RF(piagg) View Post
    Sent.
    There isn't really any way to tell definitively what version or restriction status the ECU is in. Sadly, there isn't much the Gameboy will tell me about the ECU, such as installed map version, restriction status, ect. What it will tell me is a read out from some sensors, engine rpm, engine state, ignition advance, throttle position, coolant temp, engine hours, error codes, etc. I can sort of get an idea of if the map on the ECU is older or newer, but not version or restriction status. If the map on the ECU is older, when I plug it in the Gameboy will automatically flash it with the newer map. If the map on the ECU is newer, when I go to flash it, it will warn me the map I am flashing is older and ask if I want to proceed. I flash 2.8.0 to everything as that is technically the latest map, expect for 2004 and older North American models with the Morini engine, as they aren't supported by 2.8.0 (and I've never cared enough to look into adding support for them like I did with the 2005-2007 Morini), but are with 2.8.2. The two "newer" maps are 2.8.2 and 2.8.3.1/2.83.1 which are specifically for the North American market. 2.8.2 only supports 2001-2004 first gen North American Morini SR50 Di-Tech, 2005-2007 second gen Morini SR50 Di-Tech (which were only release in the US, Canada, Australia, and maybe few other countries I've forgot, most of the world got Piaggio engines starting in very late 2004), and all year Morini Scarabeo Di-Tech. 2.8.3.1/2.83.1 is the same, but adds support for Piaggio engines. 2.8.2 and 2.8.3.1/2.83.1 were released to fix the SLOP problem that was apparently more common in North America. 2.8.2 makes very slightly (negligible really, less than 0.1 HP) less power than 2.8.0, but still had some slop problems. 2.8.3.1/2.83.1 pretty much cured the SLOP problem, but made very noticeably less power.
    #1 Forum Loser
    Dec 2011
    NC
    Hey William the third, I cannot figure out how to private message you. I am not a stalker, I live in Asheville too and I'm having issues with me 2001 sr50 ditech. I see you know a lot about these scooters and I was hoping to pick your brain. If you could help me that would be great. My email is <email address removed>. Thanks, hope to hear from you soon
    Last edited by William the Third; 06-13-2019 at 09:30 PM. Reason: email address removed
    apriliaforum expert craigo298er's Avatar
    Jun 2012
    843>440
    Quote Originally Posted by motulken View Post
    you need 10 forum posts to PM
    Last edited by William the Third; 06-13-2019 at 09:31 PM. Reason: email address removed
    7H3 M345UR3 0F 1N73LL163NC3 15 7H3 481L17Y 70 CH4N63
    4L83R7 31N5731N
    May 2019
    USA
    Hi William, I just bought a 2009 sr50 and Id like to flash my ECU to development mode. Send me a private message. Thanks
    May 2019
    WI, USA
    Hello, I am hoping you can assist me with determining whether my ecu is restricted or not. I have <10 posts so if you could send me an email that would be great!
    Thanks!!
    May 2019
    USA
    Does anybody have William’s email address?
    Oct 2003
    Asheville, NC
    Hey, sorry about not replying sooner, just been crazy busy recently. Hopefully I'll have some time tomorrow or this coming week to contact/reply to everyone.
    #1 Forum Loser
    Jun 2019
    KC MO
    William
    in need of your services, For a 2009 Factory. Please PM when you can.
    thank you
    Oct 2003
    Asheville, NC
    Quote Originally Posted by chris1210 View Post
    Quote Originally Posted by apriliamotor View Post
    Thanks!!
    Quote Originally Posted by ERICN View Post
    William
    thank you
    Emails sent to each of you.
    #1 Forum Loser
    Jul 2017
    Belfair,Wa.
    I have a 2008 sr50 ditech with a Malossi 70cc kit and would like to convert it to use a carburetor.What parts will I need and can you convert my ecu to use a carb?Thank you for your time.Ted Gierke trumpet1946@wavecable.com
  1. Trying to find the previous owner of my Tuono
    By CalamityConcept in forum Tuono 1000 R and Tuono Factory (2006-2010)
    Last Post: 09-22-2011, 07:28 PM
  2. You try to protect the bike....
    By rider14 in forum RSV Tuono, Tuono R, Tuono Racing, and Tuono Factory (2002-2005)
    Last Post: 08-17-2009, 02:21 AM
  3. Trying to imitate the SR50
    By panic in forum Scarabeo 50 Ditech, SR 50 Ditech, SR Factory
    Last Post: 12-14-2006, 03:35 PM
  4. trying to get the mille r on the track
    By r1y2k in forum Aprilia Privateer / Club Racing
    Last Post: 02-27-2005, 08:34 PM
  5. Be careful when trying to undo the battery connections!
    By JonnyRS50 in forum RS125 Euro-archive
    Last Post: 07-27-2004, 05:36 PM
