Results 1 to 11 of 11
Thread: 2013 rear brake clip is weird, can't figure out how to remove
    Jan 2018
    Peoria IL
    I can't pull it up, should I push it down to release pressure on the brake pin? Anyone have any experience with these? I just swapped the pads in my C14 in about 10 minutes. I'm afraid to break it?
    Thanks!
    2013 Tuono A-PRC, 2012 Concours 1400
    apriliaforum expert plocky's Avatar
    Oct 2015
    Tasmania
    yes push down lightly to release pressure on the pin so it can slide out after you remove the retaining clip from the other side off the pin.
    reverse for assembly.
    Note how the backing plates are installed so you put them back on the correct way..
    2015(16) RSV4 RR Ascari Black 201HP
    Jan 2018
    Peoria IL
    There is no retaining clip, apparently it's just spring pressure.
    Oct 2015
    Tasmania
    Quote Originally Posted by cpsmith58 View Post
    Ok, guess they have evolved over the years, mine has a retaining clip.
    Oct 2015
    Tasmania
    looked up an old 2009 RSV4 manual & they had a retaining clip as well.
    Sure your's isn't missing?
    It will be obvious if there was supposed to be one as there will be a recess at the end of the pin for it or maybe a hole for a split pin.
    Take a pic of the pin when you get it out, would be interesting to see if it has grooves for the spring to hold the pin in place.
    hard to tell from your photo above.
    Just looked up parts manual for your Tuono, says pin & split pin?
    Oct 2015
    Tasmania
    More investigation shows that yours should have a clip.
    Rear Brake Pin Retainer Clip (MC98317A214)
    Rear Brake Pin Retainer Clip, Sold each
    For Aprilia:
    • '98-'03 Mille, Mille-R
    • '00-'03 Falco
    • '02-'05 Tuono
    • '01-'07 Caponord
    • '04-'09 RSVR, RSVR Factory
    • '06-'10 Tuono
    • '11-'15 Tuono V4 (all variants)
    • 16-'18 Tuono V4 1100 (all variants)
    • '09-'18 RSV4 (all variants)
    For Piaggio:
    • '07-'11 Piaggio MP3 250
    This is a retainer clip for the rear brake pad pin used on the above listed models. This clip is normally only available as part of the complete pin kit AP8113752 which is 5 times more expensive.
    Sold each
    $1.49
    Live Stock Status:
    5+ In Stock, Ready to Ship Now
    Product Inquiry
    Add to Favorites
    Jan 2018
    Peoria IL
    I have a clip. It's the world's smallest crappiest clip and a bit mangled, but it's all back together.
    Thanks for your effort, it was very helpful!
    Oct 2015
    Tasmania
    For a $1.50 you could afford a new one.
    Jan 2018
    Peoria IL
    $38.50 by the time I bought 5 and the pin itself, but hey, I prefer my pads attached!
    Thanks again, Kiwi!
    Oct 2015
    Tasmania
    Thanks again, Kiwi!
    them's fighting words, geography not your best subject.
    No Kiwi, we have Tasmanian Devil, Tasmania is the land once known as the Apple Isle. South island of Australia.
    Quite a bit West of NZ (New Zealand) where the Kiwis are.
    Pleased to help you out any way, this time.
    Jan 2018
    Peoria IL
    Oops, not NZ, Tasmania. My bad. I actually asked a guy once if he was from NZ, I picked up the accent. Points for me there, which I just lost.
  1. How to remove Shiver Rear Brake Caliper?
    By Keith F in forum 2008-2016 Shiver 750 / Dorsoduro 750
    Last Post: 11-29-2016, 05:01 PM
  2. Rear brake caliper is total poo... Who has a HPK
    By dastrix in forum 2010-2019 RSV4 - All Variants
    Last Post: 07-20-2014, 08:37 PM
  3. can`t unlock the seat to remove it - video clip help needed.
    By filmcell in forum 2006+ Pegaso Trail / Strada / Factory
    Last Post: 01-12-2013, 07:16 AM
  4. Seat is crooked, can't figure out why...
    By jmardy in forum RSVR and RSVR Factory (2004-2009)
    Last Post: 04-12-2012, 12:46 PM
  5. rs50 rear brake light : is it possilbe to get a LED one?
    By Matt_151 in forum RS50 Technical
    Last Post: 01-16-2011, 11:45 PM
