Results 1 to 5 of 5
Thread: Sportcity charging problem, once solved, broken again, help help
    apriliaforum prov-nov Finprilia's Avatar
    Jan 2017
    Finland
    Hey,
    about month ago my Sportcity 250 stopped charging.
    I ordered new voltage regulator and everything was ok.
    I also put extra ground wire from battery to body.
    Today was a shock.
    Charging only 11.5v.
    What in the earth can it be?
    Earlier also measured voltage coming from magneto/flywheel and it was ok.
    apriliaforum Member Pinkscoot's Avatar
    NC
    A bad replacement part? Possibly bad connector or wire in the mix?
    Italian scoots owned: 2003 Scarabeo 150, 1998 Italjet Velocifero, 2009 Vespa GTS 250, 2012 Vespa S50, 2007 BV 250, 2014 Aprilia SR50 Purejet, 1977 150 Sprint Veloce (future project) and Vespa ET2 (future project)
    Jan 2017
    Finland
    Really do not know what happened, but after I took of almost all panels and covers the bike started to charge normally.
    Not happy with the outcome because did not find where the problem was but what can I do.
    Put all back today and moved on.
    need check yellow stator wires VERY WELL! there is a break somewhere or breaks when moved a certain way etc.. you replaced stock regulator ? most go MOSFET shindengen stock is not so good ..
    the yellow wires grommet wer it penetrates case is always suspect.
  1. Battery/charging problems... problem solved?!
    By SmaRTrxxv in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 03-11-2013, 02:24 AM
  2. Charging problems - help please
    By Clarkey_UK in forum RST1000 Futura (all years)
    Last Post: 03-25-2011, 06:35 PM
  3. Charging Problem - solved??
    By Felix Da Cat in forum RSVR and RSVR Factory (2004-2009)
    Last Post: 04-09-2006, 01:21 PM
  4. RS50 Charging Problem **HELP**
    By runvusofme in forum RS50 Technical
    Last Post: 05-05-2005, 01:40 PM
  5. charging problem, Help Please
    By Big-Bore in forum RS125 Euro-archive
    Last Post: 04-06-2004, 10:58 AM
