Page 3 of 3 FirstFirst 123
Results 31 to 35 of 35
Thread: Pressure oil Lights up
  1. #31
    Dec 2018
    greece
    Hm ... i am wondering for 2 things
    1the smoke that came from the air hoses and
    2 for the noise that the starter does
    It's seems to me that there is a head gasket problem with losing water inside the cylinder causing the starter to spin with difficulty
    Ps the smoke came out of the air hoses i bet that is water or paraflu
    Στάλθηκε από το Mi A2 Lite μου χρησιμοποιώντας Tapatalk
  2. #32
    Jan 2015
    Portugal
    Hi,
    The head gasket is new and the head has been repair and tested, but we never now...
    There is a easy way find if water is inside of cylinder?
    regards
  3. #33
    Jan 2015
    Portugal
    Hello,
    one more help please in tdc lock the flying wheel is in the correct position see in photo.
    Untitled by Samuel Sousa, on Flickr
    Camshaft position
    Camshaft movement
    The noise is my air compressor working
    Regards,
  4. #34
    Sep 2015
    Fayence
    Take out the spark plug and look down the hole with an endoscope. They're very cheap to buy as an attachment for your smart 'phone these days.
    If your crank is locked in the TDC position, something is not correct with your cam timing. The lines on the cam sprockets should be absolutely parallel with the top of the cylinder head. I suggest you may be one tooth out... whatever the cause though, something is not right.
    Cheers... Paul
  5. #35
    Jan 2015
    Portugal
    Thank you again!
    I will see this and try align the sprockets.
    And the flying wheel is ok?
    Regards
  1. Pressure oil light, engine off
    By ITAsxv in forum 2006-2011 Aprilia RXV, SXV, MXV 4.5/5.5 V-Twins
    Last Post: 05-16-2016, 12:13 PM
  2. Oil Pressure Warning Light related to cold weather?
    By bigdawg8330 in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 10-23-2008, 04:47 PM
  3. Oil pressure warning light
    By banbury biker in forum SL1000 Falco Forum (all years)
    Last Post: 10-18-2008, 11:55 AM
  4. Oil Pressure Warning light?
    By chmccand in forum RST1000 Futura (all years)
    Last Post: 04-18-2007, 06:41 AM
  5. Oil Pressure Warning Light
    By ckusa in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 12-22-2004, 12:27 AM
