Page 8 of 8 FirstFirst ... 678
Results 106 to 109 of 109
Thread: Rs4 50 2018 aftermarket exhaust and upgrades
  1. #106
    Jul 2018
    France
    This is the current discussion Im having to see whats the best suited 70cc pipe to put on to the bike at the moment , as you can see there are a few to choose from like Kaldis says look for the DB050 engine and the cc that you are installing.
    https://www.gprcamp.com/foro/viewtop...9543&start=350
    For the euro 4 its just emissions, there's a whole bunch of pipes and a regulator valves that goes from the exhaust to the engine and back to the air box. All of this can be removed! and the air box plugged up and the same goes for any off takes to be closed off.
    When I started this I was a bit nervous of messing things off and unsure if the bike would work properly, but now ive done it it seems fine.
    speak soon cheers
  2. #107
    Jan 2019
    España
    Hi guys
    that is the confirmation I needed thanks kaldis.
    and now ... what opinion do you have of yasuni r2 exhaust? Could it be a good option?
    Can it fit well with the 70cc metrakit cylinder kit?
    If you do not have any negative opinion, I think that is my chosen one.
    thanks for everything!!
  3. #108
    May 2018
    Hungary
    You can choose Yasuni R2 or R3 depending on your setup/needs. They are pretty great exhausts. You can just fit it on without any mods. R2 has thr powerband lower, the R3 has it higher. If you want to build later an 80cc setup then go for the R3. If you dont then go for the R2.
  4. #109
    apriliaforum expert Rj_666's Avatar
    May 2013
    Seattle, wa USA
    I run a R2 on my setup... good street kit. Generally good, through all RPM ranges, but the bike is geared for higher top speed (opposed to low end acceleration).
    I'm planning a sportier build this spring, and will add a R3 to the build (planning a 86cc TP kit, with 24/28 mm carb)
    =My Iron Maiden=
    1999 Aprilia RS50
    Doppler endo crank
    Barnett Clutch
    Stage6 24mm PWK clone w/powerjet
    Pre-mixing Trick 101 octane / Motul 800 @38:1
    Top Performance 8 petal Reed Block w/ Stuffer
    Top Performance TPR aluminum, 50 mm piston, 1 ring
    Yasuni R2 Carbon Exhaust
    13/43 final gearing
    AF1 spring upgrade & 'Martin77 / Mattology' preload adjusters
    DNM 'MT-Bag' 3 way adjustable rear shock absorber
    Mitas MC50 tyres
    Brembo RCS 14 front master / NG rotors / Ferodo pads
  1. aprilia rs4 50 , which new exhaust
    By joshua.winch in forum RS50 Off Topic
    Last Post: 04-29-2017, 12:23 PM
  2. Replies: 32
    Last Post: 11-26-2016, 02:53 AM
  3. Aftermarket exhaust and gaskets. Need opinions on this...
    By Thr3e5ive in forum 2008-2016 Shiver 750 / Dorsoduro 750
    Last Post: 07-28-2016, 06:42 PM
  4. 05 vs. 06 SR 50 Factory aftermarket Exhaust
    By JohnnyStang06 in forum Scarabeo 50 Ditech, SR 50 Ditech, SR Factory
    Last Post: 06-26-2007, 12:12 AM
  5. Has anyone got and aftermarket exhaust for sale?
    By 98shaikh in forum RS50 Technical
    Last Post: 09-06-2003, 04:00 PM
