Results 1 to 14 of 14
Thread: Diagnosis of clutch unhappiness
    Mar 2012
    On the road between ID & OR
    On the way home from a 150-ish mile ride, and the clutch lever started feeling a little "soft". By the time I got home, the lever was only working in about the last 1" of travel. Fluid is a couple of years old, and at the right level.
    So, is it likely the master cylinder on the handlebar, or the slave, and how do I diagnose that? I suspect it's the master, and if it is, has anyone switched to the RSV-R master and reservoir?
    JD - Hurricane Nuker
    Futura
    Bunch of dirtbikes
    Sweden, Linköping
    Bleed the clutch first.
    When holding the clutch lever in to the handlebar and you feel after a while the force to hold it is reduced, the master is bad.
    Happend to me. Ended up getting Ducati coffin style radial masters. The older mille has the same piston in the master so find a crashed one and just take the piston. There is a company in england selling seals (search the forum) but installation of them is a bit tricky.
    Mar 2012
    Will do - thank you
    Futura
    Bunch of dirtbikes
    Mar 2014
    California
    Our OEM Brembo clutch master cylinder is a unique one, as it holds about 5cc of fluid. Problem is that the diaphragm / reservoir cover seal takes up 90% of the area in that reservoir. Like Deefred suggests, bleed this system first, you'll find some really nasty fluid in there.
    The piston seal could be worn, allowing a bit of air to enter the system. Best method to bleed the clutch system is to rotate the handlebar so the reservoir is level. Place a drop cloth of fender protector, beach towel, or a pillowcase if the wife isn't looking, over your fuel tank, instruments, and the acrylic windscreen.
    Clean both sides of the diaphragm, you'll find the "upper" side will have wet nastiness (condensation) as well.
    You'll find that Brembo designed this master as an homage to mighty Vesuvius, be really careful during that first few millimeters of lever travel! As the bypass port is open, she'll erupt brake fluid like crazy. To access the bleeder, remove the left fairing covers.
    Mar 2012
    ^Great info as always - gonna be a few more days before I can get to it, but will report back.
    Futura
    Bunch of dirtbikes
    Mar 2014
    California
    Good stuff! If your external dust seal is tearing, by the way, look up this part in the RSV mille section. It's not listed separately in the Futura section, though the dust cap is the same Brembo part.
    I bleed the clutch every few months, it goes black in nothing flat. Clutch feels awesome with a fresh fluid change.
    Bob
    Jul 2004
    Cincinnati
    https://www.af1racing.com/store/Scri...idProduct=2382
    Pull the clutch slave, replace the seal, bleed all the old nasty fluid out, happiness is a smooth, progressive, clutch.
    '02 with lots mods: full race airbox, evo filter, mille intake, H-pipe, staintunes, PCIII, Carbon Hugger,Custom Gloss Black Paint, Custom silver powder coated wheels and other bits, Billet aluminum (well O.K. Home Depot Aluminum Strap) Pivot Covers, Throttlemeister. Looking for full radar and laser stealth technology!
    Mar 2012
    Thanks guys. Been busy of late as my Dad passed away recently, but I'll report back once I get it fixed.
    Futura
    Bunch of dirtbikes
    Jan 2005
    Annapolis, Maryland USA
    Here we go again.
    Putting some eyes on the underside of my clutch slave, it is dribbling again, as seems usual.
    It has not emptied the reservoir after about 1 year, but clearly leaking.
    I have never been able to stop the slave from leaking.
    It has a fresh, new seal as of 18 months ago, and the cylinder walls are flawless.
    It was cleaned well, and bled out carefully then.
    Still a great mystery why these things leak.
    I am using Valvoline DOT 4 synthetic fluid.
    Stock Aprilia seals from AF1.
    I wonder if somehow daily temperature variations create a small but constant pressure, pushing the fluid past the seal.
    Is there perhaps a seal from another brand of bike which might behave better?
    Also, are there any crosses for the clutch master seals, or the front brake master seals?
    Nov 2009
    McDonough Ga. Or Northeast Connecticut
    Are you sure its not oil drippling down ? I was getting a small leak from same area and it was the seal for the clutch rod. I replaced the clutch rod as it was showing some wear as well as the bearing and seal and no more dribble.
    Jan 2005
    Quote Originally Posted by ga. grizz View Post
    It may well be the pushrod seal. It was not clear with all the grunge. I will keep an eye to try to determine.
    Of note, the clutch had not leaked down since last year, so very possible it is the pushrod seal.
    Just placing the breadbox back after replacing exhaust gaskets, so took the time to clean off the bottom side.
    Seemed like DOT fluid at the moment, but we shall see.
    Thanks...
    Sep 2019
    UK
    After chasing seals for my Futura "Brembo" Master cylinder I can confirm the following part numbers.
    The actual dimensions of the Master piston/bore it is to fit is 12mm od x 7mm id x 4mm SU12-7-4-EP-DS106 IS CORRECT
    The actual dimensions of the Master piston/bore it is to fit is 12mm od x 5mm id x 4mm SU12-5-4-EP-DS106 IS CORRECT
    The actual dimensions of the Slave piston/bore it is to fit is 28mm od x 20mm id x 4mm wide SU28-20-4-EPDM-DS106 IS CORRECT
    The suppler is FPE Seals Ltd, 7 Barrington Way, Darlington, County Durham, DL1 4WF, England.
    The staff are extremely helpful.
    Mar 2005
    South France
    It help with some pics : https://www.apriliaforum.com/forums/...-Seals-Sourced Then replace "grey" DOT liquid & bleed & bleed again .....
    Mar 2012
    Forgot about this thread... bled (burped) the clutch a couple of months ago, and everything is happy again.
    Futura
    Bunch of dirtbikes
  1. A new type of clutch failure!
    By Emanon in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 02-08-2008, 06:43 PM
  2. Damn cable came out of clutch lever when I was riding
    By John D in forum RS125 Euro-archive
    Last Post: 11-11-2005, 01:57 PM
  3. Setup of Clutch and variator
    By Topper in forum Scarabeo 50 Ditech, SR 50 Ditech, SR Factory
    Last Post: 08-02-2005, 06:23 AM
  4. Fluid Spray out of clutch reservoir
    By WAZZU_Mille in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 07-24-2005, 09:54 PM
  5. Hard Time Finding Neutral-- Sign of Clutch Slave Issue??
    By PNorris in forum RSVR and RSVR Factory (2004-2009)
    Last Post: 10-11-2004, 04:25 PM
