Results 1 to 15 of 25
Thread: Rectifier relocation for Track bodywork
    Feb 2017
    Van Nuys
    Hi guy,
    I've fitted my bodywork and am now wonder whats the most common solution for relocation of the rectifier and the other component which is mounted to the inside of the left mid fairing panel?
    I have a '16 and motoX bodywork.
    On the AF1 site I saw they sell a regulator bracket (states '17 model), but haven't found much else.
    Your guidance is greatly appreciated
    Cheers.
    apriliaforum newb Sidi9000's Avatar
    Apr 2018
    Richmond VA
    I have it vertically mounted on the very front center of the oem stay with one bolt bushing and lock nut. Donít remember if there was a hole or Iíve drilled it. Been there for 3 years, itís solid and doing just fine. Iíll shoot you a picture tomorrow when around it.
    Sent from my iPhone using Tapatalk Pro
    Oct 2015
    Tasmania
    apriliaforum Junkie EricD's Avatar
    Jul 2012
    San Jose, CA
    I bought the bracket from AF1 that goes where the canister would be from stock.
    When in doubt, gas it
    apriliaforum expert flobrandx's Avatar
    Mar 2015
    Washington
    I’ve seen pics of them mounted OEM stay as mentioned by Sidi9000 and here are a couple other bracket options to mount down below on the side.
    http://www.af1racing.com/store/Scrip...acket+for+RSV4
    https://www.hsbkracing.com/parts-and...-bracket-2017/
    I have the Aprilia Racing one from HSBK.
    2017 RSV4 RF (x2) - (1) FOR SALE
    2010 RSV4 Factory - SOLD
    2014 Beta 520 RS
    OMRRA #99
    Sponsored by:
    Aprilia Portland
    HSBK Racing
    Cox Racingroup
    Oct 2015
    Tasmania
    All the information on how to mount to the OEM stay is in the PDF I linked to, with pics & all.
    Mar 2015
    Washington
    Nice job plocky! You’re a great member with a wealth of info for this forum!
    2014 Beta 520 RS
    OMRRA #99
    Sponsored by:
    Aprilia Portland
    HSBK Racing
    Cox Racingroup
    Oct 2015
    Tasmania
    Thanks, flo, I cheat a little, lol, bookmarking good info is my habit.
    Luckily Aprilia freely give out this info.
    There is more info on other subjects at http://www.aprilia.com.au/pdfs/
    Feb 2017
    Van Nuys
    Brothers, thank you for your replies, I truly appreciate your input. I will look closely at this info and make it work on my moto.
    Cheers mates.
    Feb 2017
    Van Nuys
    Guys, I'm curious about the module on the inside of the left mid fairing. What is it for and where should it be relocated?
    Cheers
    Nov 2017
    california
    Looks like the hsbk mount is for 2017+ My 2016 has other stuff in this real estate.
    Jul 2012
    San Jose, CA
    Quote Originally Posted by GJB View Post
    The 2017 bikes also have "other stuff in that real estate". Mainly, the whole EVAP canister. On my track bike, I removed the canister and mounted the backet + rectifier there.
    Oct 2015
    Tasmania
    Quote Originally Posted by GreenJackal View Post
    Cheers
    Read the PDF.
    Mar 2015
    Washington
    Cheers
    On the 16’ you would have to mount it on the rights side as the left side has the throttle cables and demand sensor. The right side would have the Evap canister you can remove.
    The 17’ has the Evap canister on the left and exhaust valve motor on the right side.
    I would check the bolt spacing and pattern on both sides to see if they are the same. You can always make your own mount out of aluminum.
    2014 Beta 520 RS
    OMRRA #99
    Sponsored by:
    Aprilia Portland
    HSBK Racing
    Cox Racingroup
    Jul 2009
    Czech republic
    my homemade bracket on 17'
  1. FS: AF1 voltage regulator relocation bracket - for use with track bodywork
    By JohnnyV in forum Aprilia Parts and Accessories for Sale / Wanted
    Last Post: 06-30-2017, 10:25 AM
  2. fasteners for track bodywork?
    By Turbinepilot2 in forum 2010-2019 RSV4 - All Variants
    Last Post: 02-09-2017, 09:49 PM
  3. working on the headlight decals for track bodywork
    By ckruzel in forum 2010-2019 RSV4 - All Variants
    Last Post: 02-13-2015, 06:35 PM
  4. WTB: Looking for TRACK bodywork, adjustable triple clamps, variable TB for 2013 RSVR
    By mouimet in forum Aprilia Parts and Accessories for Sale / Wanted
    Last Post: 12-22-2014, 10:31 AM
  5. Track bodywork for sale
    By jerrytlr in forum RS250
    Last Post: 07-24-2003, 04:48 AM
