Thread: Wiring diagram with good resolution Sportcity 250?
    apriliaforum prov-nov Finprilia's Avatar
    Jan 2017
    Finland
    Hey there,
    Does anyone have Sportcity 250 Workshop manual that has wiring diagram with good resolution or just the diagram itself that has clear picture?
    The one I downloaded here somewhere is so blurry that it is useless, all the other pages are clear but wiring diagram pages are blurry.
    My problem is that after two week holiday I tried to start my Sp and the battery was empty, worked ok before the holiday.
    So I thought the battery was gone and bought a new one and of course scooter started ok but then I looked the voltage on display and it was only 11.5v.
    I also measured voltage directly from the battery and it showed the same, 11.5v.
    Revving the engine does nothing to voltage reading.
    I took floor panel off and checked all the connections between battery, voltage regulator, fuses, etc. etc, and they were all fine.
    So, it is not charging ok.
    I admit I was too anxious to get it fixed and I ordered a new voltage regulator right away, I have had voltage regulator fails with 50cc scooters way back ago and I thought it could be the regulator causing the problem.
    I did not remember that if regulator is gone it usually gives over voltage not under and I am afraid the problem might be somewhere else.
    It is gonna take some time the regulator to get here in Finland so I thought I would measure the voltage from the magneto but without the wiring diagram it is impossible.
    Also, if anyone has any ideas where look for the problem all help is welcome. (sorry my broken english)
    apriliaforum Member Pinkscoot's Avatar
    Aug 2016
    NC
    It's obvious that the Voltage regulator isn't putting out the power. Is the stator sending it the correct power? Find the wire running from the stator and pull that plug test the AC voltage from found to the connectors. Should be around 60VAC when the engine is revved. If you get that then work your way back and see if you find a bad connection.
    Italian scoots owned: 2003 Scarabeo 150, 1998 Italjet Velocifero, 2009 Vespa GTS 250, 2012 Vespa S50, 2007 BV 250, 1977 150 Sprint Veloce (future project) and Vespa ET2 (future project)
    Jan 2017
    Finland
    Ok, now I tested the stator, on the idle it gave about 20ac and when revving about 60-70ac, so I think it is ok.
    I found "how to test voltage regulator diodes" on Youtube and following that I also tested my regulators diodes and they seem to be fine.
    So, I am little bit confused whats wrong, why is it not charging, only 11.5 out of regulator.
    Of course I admit that I do not understand horse`s ass about scooter electronics as you can see and so I don`t know can there be something else besides
    the diodes broken in the regulator.
    Certainly hope so.
    This just came to the worst possible time this error, that`s why I am so nervous with this situation.
    Taking scooter to the dealer is no option for me, gotta handle these problem by my self.
  1. Is fuel with Ethanol OK for my SportCity 250?
    By dhiggins in forum Aprilia and Piaggio 150cc-350cc
    Last Post: 10-08-2012, 11:57 AM
  2. 250 challenge wiring diagram?
    By zapped in forum RS250
    Last Post: 11-08-2011, 12:41 AM
  3. High resolution copy of the wiring diagram
    By High Gain Tuning in forum Scarabeo 50 Ditech, SR 50 Ditech, SR Factory
    Last Post: 10-08-2008, 02:18 AM
  4. MPG of Sportcity 250 with J Costa Variator
    By bikemonster in forum Aprilia and Piaggio 150cc-350cc
    Last Post: 04-26-2008, 04:58 PM
  5. High-Resolution Wiring Diagram, ECU Pinout, Circuit Descriptions
    By Jim Hubert in forum 2006-2011 Aprilia RXV, SXV, MXV 4.5/5.5 V-Twins
    Last Post: 02-13-2008, 12:25 AM
