Results 1 to 2 of 2
Thread: 200 speedometer contact
    apriliaforum expert ispud's Avatar
    Jul 2008
    My speedometer has not been working for over a year. I tried checking it out but really didn't know which way top go. I would like to contact Aprilia and ask for some direction, but their website is treacherous to say the least...definitely designed to keep me out. Does anyone have an email of someone who might be knowledgeable? If so mine is jacksmetal@gmail.com. I posted here when it first occurred, but no replies.
    Ispud
    2008 200 Scarabeo (fool me once) spooky
    2009 Kymco People 250 S Work horse
    2006 Honda Big Ruckus (sold 10-14)
    2004 500 Scarabeo Cadilac
    2006 S250 sold for top dollar
    2013 BV350 screwing with me bit time
    2009 SC250 Cube (whatever that means) sold...never liked it
    apriliaforum Member Pinkscoot's Avatar
    NC
    I usually start by pulling the headset and then the cable from the bottom of the speedometer. With the tab that goes in the speedometer sticking out of the cable I spin the front wheel. If the tab turns then the problem is in the speedometer. Open the speedometer and spin the part that the tab sits in and see what's going on. If the tab doesn't turn go to the wheel and disconnect the speedo cable and see if the tab is sticking out there, sometimes the cable will start to slide out. Then turn the tab and see if the one at the top is spinning. If it is spinning then the problem is in the puck on the wheel. If not then the cable is broken. If its all good to this point make sure the puck is seated properly and look inside as you spin the tire and see if the gear inside is turning. As a last resort pull the puck out and find what's broken.
    A couple of months ago I had a rash of bad speedometers and they were all solvable with this trouble shooting. Sometimes its as simple as tightening the cable on both ends or replacing it. On the LX50 I rebuilt it was opening the speedometer and turning it then putting it back together. I did have one that the part in the wheel was broken so it wasn't turning the puck. I put it back together and walked away, the scooter never went much faster than 30mph any way. Just take your time and start at one end and work your way to the other.
  1. Sportcity 200 speedometer speed indicator not working
    By RS 13 in forum Aprilia and Piaggio 150cc-350cc
    Last Post: 03-08-2012, 04:02 AM
  2. How accurate are U.S. speedometers?
    By 2cats in forum RST1000 Futura (all years)
    Last Post: 04-25-2003, 07:50 AM
  3. How To Contact CE2?
    By DeTuono in forum Professional Racing Discussion
    Last Post: 04-07-2003, 07:00 AM
  4. Speedometer Sensor
    By SDfalco in forum SL1000 Falco Forum (all years)
    Last Post: 11-14-2002, 08:49 PM
  5. Here's the contact for the Bitumo shocks lets order them now
    By biggums in forum SL1000 Falco Forum (all years)
    Last Post: 10-22-2002, 03:58 PM
