Page 7 of 8 FirstFirst ... 5678 LastLast
Results 91 to 105 of 107
Thread: got the carbon bike together, finally
  1. #91
    Jun 2009
    Saint Petersburg, Florida
    lol no way it's only 20 feet x 20 feet! small, but big enough for me!
    the 3d printer is on the same table as the white cylinder thing. the white cylinder thing is the heater/dehydrator for my filaments. if you don't dry them before printing you can't successfully print nylon and other high performance filaments.
    if you look just behind the dehydrator you will see the vertical chassis of the printer, and it's power supply/ control box. i'll get a get photo when i get home today.
    edit:
    pic
  2. #92
    Jun 2009
    so here's a new one..
  3. #93
    Feb 2011
    NZ
    Reverse bolts?
    Head to the Cushdrive side...
  4. #94
    Jun 2009
    rear BST with sprocket = 10.8 lbs
    stock wheel with sprocket = 15.6 lbs
    no brake rotors attached.
    i took those little rear plates off, and while they are a little bit flimsy with the rear wheel not attached, once you tighten the rear axle, everything is solid as can be. i will look into reversing the bolts and making them low profile and seeing whether i like it with how much clearance it would have...
  5. #95
    apriliaforum prov-nov Dextroyer's Avatar
    Feb 2017
    Port Richey, Florida
    This is RAD!
  6. #96
    Jun 2009
    stock front wheel - no rotors 8.8 lbs
    BST front wheel - no rotors 4.8 lbs
  7. #97
    Jun 2009
    can't wait for my forks to come back now... need to order front brake hardware also
  8. #98
    Feb 2011
    NZ
    OK, you've finally done it...
    Taken the first prize for RS250 porn.
    Well done sir!
  9. #99
    apriliaforum Junkie AV80R's Avatar
    Apr 2017
    Northern CA
    Wow Matt! That's a heck of a weight savings and a drool worthy photo
    CAUTION - My forum posts may be worth what you paid for them!
    2000 RS250 Tetsuya Harada Replica - Street
    1996 RS250 Alex Debon Lotus Replica - Street
    1999 RS250 Cup Challenge - Track
    1999 RS250 basket case currently in pieces! - Street
  10. #100
    apriliaforum Junkie chadzilla1's Avatar
    Apr 2016
    miami, usa
    nice looking rims for sure
    1999 RS 50
    Stock engine, stock pipe, giannelli can
    Dellorto PHBG 17mm AS carburetor
    atomizer = 262 AU
    main jet = 86
    idle jet = 52
    starter jet = 60
    float = gr .4
    needle = W7
    slide = 40
  11. #101
    Jun 2009
    well, i found out why my forks were taking so long...
    the platers accidentally left the tubes in the chemical strip process for too long and ruined my tubes, they're pitted beyond repair.
    so, they had to order a brand new set of fork tubes for me.
    at this point, it would have been cheaper just going the route of custom triple clamps and full ohlins RT forks.
    bike probably won't be ready for the show i was planning on attending either.
    pffffft
  12. #102
    Nov 2009
    Michigan
    Bugger!!!
  13. #103
    Jun 2009
    forks have finally shipped... should get them later this week. can't wait to put them on the bike and start machining up the spacers as needed to mount my brake tech rotors and the front BST
  14. #104
    apriliaforum expert grendels_arm's Avatar
    Aug 2005
    Northern, VA, USA
    Quote Originally Posted by mattology View Post
    Congrats man. Your bike is real nice.
    Sam
    USGPRU #98
    1998 Honda RS125
    1998 Aprilia RS250 Cup bike
  15. #105
    Jun 2009
    well, first update,
    after FIVE MONTHS I finally got the forks back this afternoon and something is obviously not right.
    1) there's an inch or so of almost free play in the very top travel of the forks. something doesn't feel right.
    2) the spindles were not coated even though i paid for them to be done, and was never notified by konflict that they were NOT going to coat them
    3) the nitride color on the fork tubes is not nearly pronounced, not at all like the demo photos they have on their site.
    4) i received no information at all on what oil was installed, what preload is set to, what the oil level is set to, etc. so i have no idea what i'm at.
    so now, they're going off to seattle, to have a personal friend go over them to make sure at least the ohlins nix30 kit is installed correctly..
    to be continued...
  1. finally got the new bike...
    By sxver in forum 2006-2011 Aprilia RXV, SXV, MXV 4.5/5.5 V-Twins
    Last Post: 04-23-2010, 11:37 AM
  2. Finally got the Ape back together
    By StefanJ in forum RSVR and RSVR Factory (2004-2009)
    Last Post: 05-27-2008, 05:46 PM
  3. got the new bike now ;-D
    By blade. in forum RS125 Euro-archive
    Last Post: 06-30-2007, 09:53 AM
  4. Just got the new Bike! and now the questions
    By crojack in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 02-07-2007, 10:25 PM
  5. Got the new bike, wooo hoo
    By spanairRS250 in forum RS125 Euro-archive
    Last Post: 06-01-2004, 06:35 AM
