Results 1 to 7 of 7
Thread: Stalling while high rpm engine braking
    apriliaforum newb crorsv4f's Avatar
    Croatia
    Hi,
    Just bought and install 2012 APRC engine in '09 Factory, check and adjust the valve (only one was little tight), calibrate the throttle bodies.
    While riding at 8000 rpm or higher and release the throttle engine became to stalling, also visible on rev counter!
    Engine has 5500km and in excellent condition, runnig fine, very powerfull while accelerating, idle is stable, no errors!
    TB pressure on vacuum gauge is -260mbar for both front cylinder, and -240mbar for both rear, but the master and slave bypass on each bank are fully closed.
    Any ideas?
    many thanks...
    Gabro Race map,
    Akrapovic silencer
    apriliaforum expert plocky's Avatar
    Oct 2015
    Tasmania
    Did you run Handle Self learning?
    Is the ECU from the old engine or new engine?
    2015(16) RSV4 RR Ascari Black 201HP
    Croatia
    Yes. I perform throttle and handle learning.
    ECU is from old engine, custom Gabro Race map 13A9AD23, I spoke with Gabro and he told me that it will run fine.
    My concern is about TB, cause they have been previously adjusted on the covered screw between bodies...
    Croatia
    Try a few combination of master and slave adjustement, but results is always the same...
    I realise that it is not happening in first and second gear, only third and higher!
    Start thinking that maybe is not the problem in TB...maybe slippery clutch or something!
    Any ideas??
    Croatia
    https://www.youtube.com/watch?v=DibwmJRlcaQ
    still no idea!!
    3rd gear during deceleration is worst...
    Oct 2015
    Tasmania
    Wow that is odd behaviour.
    Croatia
    yes, very odd!!
    i have checked vacuum pipes and flange on TB for air leaking but everything seems ok!!
  1. Engine sputter & stall while riding
    By beatdownpro in forum Pegaso 650 Cube and IE
    Last Post: 09-30-2017, 08:02 AM
  2. Engine stuttering (almost stalling) when hard on the brakes?
    By Fangit in forum 2008-2016 Shiver 750 / Dorsoduro 750
    Last Post: 06-20-2013, 09:17 AM
  3. engine stall while riding
    By sav in forum SL1000 Falco Forum (all years)
    Last Post: 10-28-2007, 08:37 PM
  4. backfiring while "engine braking"
    By ride-red in forum RSV Tuono, Tuono R, Tuono Racing, and Tuono Factory (2002-2005)
    Last Post: 09-09-2006, 06:27 PM
  5. High RPM engine failures...
    By keean in forum RS250
    Last Post: 09-01-2004, 09:50 AM
