Results 1 to 7 of 7
Thread: Caponord fuel pump replacement
    Mar 2005
    A few monthes ago i was looking a fuel pump to replace my Caponord's fuel pump.
    It was difficult to find fuel pump's infos but some members from the forum helped me.
    I decided to show you the procedure i kept to replace it.
    I bought this fuel pump, which cost me with the shipping costs from Germany to Greece 40 euros
    Here you can see the difference from the original. The main body is a little shorter.
    I removed the tank from the bike and i unscrew the ten screws that hold the pump and the filters on the tank.
    Carefully i removed the entire mechanism and then i cleaned thoroughly and removed any residue from flanges on both sides, reservoir and mechanism.
    It is good to clean the entire tank.
    I also replaced the main fuel filter.
    Mar 2005
    I also bought a new strainer.
    It is shorter than the original but it can handle the specs of the fuel pump.
    Mar 2005
    Let's assemble them.
    Mar 2005
    Mar 2005
    I had to lower the inner part of the tank, because the strainer had n't the angle of the original.
    And i had to clean the tank again.
    Mar 2005
    After thoroughly drying, I put a little of the following sealing material perimetrically and externally of the o ring for better waterproofing.
    apriliaforum expert Nito's Avatar
    Apr 2013
    Canterbury, Kent
    Nice clean job. Is it worth replacing the bellow pipe (from filter to pump) while you are there as these have been known to split.
    I need to go into my tank soon as my fuel sender isn't working correctly so it's useful to see your pics, thanks for sharing. I like the use of Metripack connector on the tank loom as well
    2018 Ducati Diavel Diesel "Nel mezzo del cammin de nostra vita"
    2008 Caponord ETV 1000 ABS- "Il Capo"
    2002 Tuono 1000 RSV-R Limited Nr.035- "Hyperthrust Cleared and Counting..."
    1993 Ninja ZXR750R "NinjaR!!"
    1992 Ducati 907IE "Il nostro passato ha un grande futuro"
    1986 Katana GSX750SE "The unbelievable Pop Kat"
  1. 2002 RSV fuel pump Replacment
    By wltrfltn in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 01-22-2016, 07:18 PM
  2. Fuel Pump replacement.
    By freco in forum 2006+ Pegaso Trail / Strada / Factory
    Last Post: 05-13-2015, 08:16 AM
  3. Fuel Pump Replacement Question
    By dragonfire in forum RSVR and RSVR Factory (2004-2009)
    Last Post: 06-02-2010, 01:10 PM
  4. Dealer out of business, I need fuel pump replaced under warranty!
    By rd400guy in forum Scarabeo 50 Ditech, SR 50 Ditech, SR Factory
    Last Post: 06-23-2009, 11:18 AM
  5. Fuel Pump Replacement
    By jwdub1 in forum ETV1000 CapoNord (2001-2007)
    Last Post: 12-10-2007, 05:40 PM
