Page 2 of 13 FirstFirst 123412 ... LastLast
Results 16 to 30 of 183
Thread: Aprilia RS250 refresh 300cc lots of new parts
    May 2010
    England.. KENT
    The rs250 has been sitting under cover in the garden for 2 years. Since moving house there was no room to put it anywhere decent. With a lot of building work being done. So the garage is finished now (we'll has walls and a roof). So first thing in there is the rs250
    Sent from my F3111 using Tapatalk
    May 2010
    England.. KENT
    The fuel tank has the normal bubbling and expanding problem. I left it for 2 weeks empty just so it would shrink back to size for the lugs to fit in. Hopefully the fuel tank Sealer will help with this problem. The caswell sealant is the only sealent recommended for nylon / plastic tanks. It does cost more than other makes but hopefully its worth it.
    Oct 2013
    los angeles
    We’re did you get the kit from?
    May 2010
    England.. KENT
    Quote Originally Posted by pablito81 View Post
    Caswell they have a website
    May 2010
    England.. KENT
    After I mix and put the sealent in I will be sanding all the paint down on the fuel tank
    Last edited by james106gti; 04-02-2018 at 04:16 AM. Reason: Imagine code not working
    Aug 2010
    Chojnice POLAND
    Engine parts look's like porn
    Wysłane z mojego D2303 przy użyciu Tapatalka
    May 2010
    England.. KENT
    caswell fuel tank sealant. the fuel tank will be sanded all the way down after this. Taptalk is no letting me upload pictures for some reason so updates will be a bit slower now
ID:	354550Click image for larger version.
    Oct 2013
    los angeles
    Quote Originally Posted by james106gti View Post
    Cant find anything online, can you post a link
    May 2010
    England.. KENT
    http://www.caswelleurope.co.uk/fuel-tank-sealing-kits/
    Mar 2018
    Tampa, FL
    The Caswell is good stuff if you have to line a tank. It holds up to the E10 gas we have here. Never used it on anything other than old steel tanks, but if they say it's compatible you shouldn't be disappointed.
    May 2010
    England.. KENT
    Quote Originally Posted by Lennon View Post
    It's the only option for a nylon tank.. It's alot more expensive than any other make.. But they do say they are the best. So hopefully it's worth it
    Oct 2013
    los angeles
    Sorry my bad, I was talking about the 300cc kit, cylinders and pistons
    May 2010
    England.. KENT
    Oh I did think that afterwards... Thetuningworks.co.uk did the 300 conversion. You need to use original cylinders aprilia or vj22
    .. Also colin on the rgv forum does his own but uses modified original heads and cut power valves.
    Apr 2009
    I would be interested to see how this turns out when done. Ethanol sucks.
    May 2010
    England.. KENT
    some more titanium. base studs
  1. 2001 & 2003 Aprilia RST1000 Futura and lots of parts for sale (US)
    By logtamelk in forum Aprilia Parts and Accessories for Sale / Wanted
    Last Post: 08-09-2016, 08:38 AM
  2. 2001 & 2003 Aprilia RST1000 Futura and lots of parts for sale (US)
    By logtamelk in forum RST1000 Futura (all years)
    Last Post: 06-27-2016, 05:34 PM
  3. [Mille] Parting out 2002/2003 Aprilia RSV Mille R (Lots of Upgrades!)
    By PumpinIron in forum Aprilia Parts and Accessories for Sale / Wanted
    Last Post: 03-23-2014, 07:28 PM
  4. Replies: 2
    Last Post: 10-26-2004, 03:36 PM
  5. Pics of new parts...
    By Craig in forum RS125 Euro-archive
    Last Post: 03-17-2004, 03:10 PM
