Results 1 to 14 of 14
Thread: Bats Aprilia RS50 D'oro
    apriliaforum expert twinturba's Avatar
    Apr 2004
    S.F
    Another Bats Project Aprilia RS50! This will be the first Bats bike to be built around the TP 85 Cast Iron kit!
    This 2005 Aprilia RS50 has been in the Bats Stable for years and has the Top Performance 75cc red (rose) kit matched to a 21mm Del orto carburetor matched with a V-force reed cage. The suspension has been upgraded with a suspension worx rear shock while the brakes have been upgraded with steel braided lines. The name D'oro meaning gold in Italian comes from the gold wheels and gold Ergal "Jewelry".
    What's to come.
    85CC Top performance with Stroker crank
    Change bearings and seals
    Fix rear brake seals
    Stay tuned.
    Jenius Biker Blog
    Current:Versys,Newd, TT, Max, Nastro, Rojo, Bangkok, 85 ADV
    Past:Typhoon, NCXD, 2X RC390s, Madass, PW50, KTM BR 65, Aprilia BR50, 2X Aprilia RS125s, DRD, WR250X, 7X Derbi SM's, 10x Aprilia RS50's, 2x Derbi GPR, 2x Aprilia RS250, 2X Mito, 2X NSR50R, NS50, HRC RS125, HRC RS80, YSR63 (1st 2stroke!), FZ600, KLR250(1st Bike!)
    I Need Parts!
    Apr 2004
    S.F
    Some updates from last weekend:
    Installed the new Apollo radiator, It's a direct swap.
    Installed the Gasket on the carburetor
    Rode a quick 10 mile ride to see if the radiator made a difference. Before i was running about the middle of the of the temp guage, after with the apollo radiator i was just above 1/4 for most of the ride.
    Still have to fix the rear brake.
    Carb fix
    Old radiator
    Comparison
    On the bike
    looking good after the ride
    Temp after radiator install
    Jenius Biker Blog
    I Need Parts!
    apriliaforum expert Rj_666's Avatar
    May 2013
    Seattle, wa USA
    Glad to see the radiator in place, and appearing to make a difference !
    What's your feeling on the Top Performances kit so far ?
    =My Iron Maiden=
    1999 Aprilia RS50
    Doppler endo crank
    Barnett Clutch
    Stage6 24mm PWK clone w/powerjet
    Pre-mixing Trick 101 octane / Motul 800 @38:1
    Top Performance 8 petal Reed Block w/ Stuffer
    Top Performance TPR aluminum, 50 mm piston, 1 ring
    Yasuni R2 Carbon Exhaust
    13/43 final gearing
    AF1 spring upgrade & 'Martin77 / Mattology' preload adjusters
    DNM 'MT-Bag' 3 way adjustable rear shock absorber
    Mitas MC50 tyres
    Brembo RCS 14 front master / NG rotors / Ferodo pads
    Apr 2004
    S.F
    Quote Originally Posted by Rj_666 View Post
    Your radiator is on the way!
    The New 85 kit has soooo much more mid range torque than the "rose" kit. It will be interesting to try with my nickel plated Jolly Moto when project "Ocho Cinco" gets going!
    Jenius Biker Blog
    I Need Parts!
    May 2013
    Seattle, wa USA
    Sweet !!
    Remind us which crank went into the 85'r ?
    Apr 2004
    S.F
    Sweet !!
    The 85 kit comes with a stroker crank. Heres a few pics of the crank from the kit which I happened to open and install today into Ocho Cinco's motor!
    Here's a look at the larger Flywheel size and the included larger size main bearing. This is a complete kit and also includes an offset woodruff key to adjust timing for the longer stroke!
    Jenius Biker Blog
    I Need Parts!
    May 2013
    Seattle, wa USA
    Nice.
    I'm a BIG fan of the 20mm main bearings, would prefer them on both sides, but flywheel side is okay too.
    My Doppler crank is similar, with the larger bearing on the fw side... I'll be looking for a 20mm on both sides with my next crank replacement.
    ontario
    what size is the exhaust outlet on the cylinder? does topperf have a pipe for such a stroker in the midrace class?
    --- custom parts and machining
    -2T&4T cylinder&engine prep,port,polish,balancing--------------------------
    -derbi bullet 2006 - piaggio AC
    https://www.apriliaforum.com/forums/...t-Tuning-Guide << Link
    May 2013
    Seattle, wa USA
    TT - did you have to cut the cases at all for this crank ?
    Apr 2004
    S.F
    Nope, fits like OEM!
    Jenius Biker Blog
    I Need Parts!
    Apr 2004
    S.F
    A little video action for D'oro
    Jenius Biker Blog
    I Need Parts!
    apriliaforum newb NoodlesRs50's Avatar
    Nov 2014
    Slough
    Quote Originally Posted by twinturba View Post
    I HAVE the same kit fitted. What was your running in procedure bud. Thanks
    Sent from my SM-G935F using Tapatalk
    Apr 2004
    S.F
    That first start we just warmed it up to the start of blue indicator 2500 rpm or less. Let it cool down overnight and the next day warmed it up to the middle of blue indicator using steady build of rpm idle as it heats up, less than 4K Rpms. Again waited until completely cold then warm up to blue and put around on the bike lower than 8k rpm, until temp reached first grey area. After 3 heat cycles it was ready to ride, progressively taking the rpm higher each ride along with temp. We have taken out for a top speed run, can see a glimpse on our intro, and it runs great!
    Jenius Biker Blog
    I Need Parts!
    Nov 2014
    Slough
    Thanks bud. Excellent stuff very helpfull.
  1. [RS50] For Sale: 2004 Aprilia RS50 with Athena 70cc kit
    By bakeme521 in forum Aprilia Motorcycles and Scooters for Sale / Wanted
    Last Post: 06-28-2013, 01:48 AM
  2. can any body tell me how to de-restrict my aprilia rs50 plz
    By ApriliaBoy in forum RS50 Technical
    Last Post: 09-07-2010, 03:53 AM
  3. Aprilia Rs50 engine For Sale on ebay MUST SEE
    By AWAY2MMI in forum RS50 Technical
    Last Post: 08-21-2003, 07:29 PM
  4. Sold the Aprilia RS50
    By tso_maltese in forum RS50 Technical
    Last Post: 07-18-2003, 09:44 AM
  5. AF1 official Aprilia RS50 Exhaust Comparo?
    By cmra47 in forum RS50 Technical
    Last Post: 05-07-2003, 03:16 PM
