Page 5 of 33 FirstFirst ... 3456715 ... LastLast
Results 61 to 75 of 485
Thread: What did you do with your TUONO today?
  1. #61
    apriliaforum Junkie Ario's Avatar
    Poland
    I heard that some Yamaha regulatora work as well.
    Quote Originally Posted by stuntmachine View Post
    I order new regulator from Honda NC700 (15eur). New starter motor replay 150amp (10eur), some company in Poland make new cables 16 from selenoid to starter motor and from battery to earth and + (20eur). This will be cheap mod. I hope to get more than 14v on the dash. We will see. I post some pics later
    Wysłane z mojego D2303 przy użyciu Tapatalka
    What I did (with my m8's huge help)
    - slipping clutch sorter
    - new head cover gaskets
    - new fuel filtr
    - rear brake bled and with Duc1098 pump working! After 7 years it is strange to have it
    - valve clearance and synchro dobę
    - voltage indicator on fashion
    - new tubes and clamps here and there
    - new front sprocket 16 teeth - Super smooth!
    Totally new bike!
    Wysłane z mojego HUAWEI GRA-L09 przy użyciu Tapatalka
  2. #62
    Poland
    And the pic
  3. #63
    Aug 2010
    Chojnice POLAND
    Where did you put signal cables to voltage indicator? I try from speedo but it show 1.5 less than battery have. What kind fuel filter did you use?
  4. #64
    Poland
    From the fusebox which is on RH side of the gauges. Reading is same as on dash, meaning it is ca. 1 Volt lower from what you get on BATT. I have the same voltmeter as you bought on Ali.
    Pozdr
  5. #65
    Aug 2010
    Chojnice POLAND
    Your Tuono should have Long end can. Short exhaust takes your Power! What? Few HP is gone? I will find them..
    Wysłane z mojego SM-J500FN przy użyciu Tapatalka
  6. #66
    apriliaforum expert Jim A's Avatar
    May 2005
    Behind the Orange Curtain, CA
    Canisterectomy today, I was surprised to find the charcoal canister and lines were still there after 15 years. The extra space under the passenger seat will be welcomed. Also did a bit more paint and some decals. Mostly to test the concept of where I want to go with the appearance. Cleaned my blue OZ rims also, a little more cleaning and they’ll be ready to go on. Also swapped the Leo Vinci slip-on for the Aprilia shotgun.
    Quote Originally Posted by Cryogenic View Post
    Growing old is compulsory............but growing up isn't!!
  7. #67
    Poland
    Shotgun exhaust is a bit long, isn't it?
  8. #68
    May 2005
    Quote Originally Posted by Ario View Post
    Optical illusion, ends same place as stock can and Leo Vinci. But I am contemplating shortening it a little, I just don't want to loose power for looks.
    So the question of the day is how much can I trim without killing performance.
  9. #69
    Aug 2010
    Chojnice POLAND
    Preparing for starter motor and battery wirning upgrade
  10. #70
    Aug 2010
    Chojnice POLAND
    Arrow long can really makes a difference. More Power everywhere. It Has 54mm inlet same like Leo vince link pipe so plug and play style upgrade
    Oil change. I have Motul 300v last year but gearbox works better on Motul 5100 so I came back to 5100 15w.
  11. #71
    Feb 2017
    Ohio
    I cleaned it, tightened up the chain and installed the new up pipes and manifolds that I had ceramic coated.
  12. #72
    Aug 2010
    Chojnice POLAND
    After not so good find in RSV I take Tuono and make new starter motor cable to prevent sprag failture. Old one look bad. I can't remove it with starter motor in the bike. So I take it off. New one is made from 25mm2 copper. It never cranks like this. 0.5 s and it running. Tomorrow I replace + from battery to starter solenoid and negative to frame and engine.
  13. #73
    Aug 2010
    Chojnice POLAND
    Now it cranks like with 100map car battery with good start cables. I try cold start and it takes 0.3s and it's running. With 2 years old ytx 12 bs
  14. #74
    apriliaforum expert VFR4Lee's Avatar
    Sep 2008
    Pining for the Fjords.
    Edit. What happened to the quote? This was at you, Jim A.
    The pipes do look long. Maybe it is the angle of the photo. Also they appear to be smaller diameter than the single can Leo, so maybe that is a factor.
    Not sure why, but I always liked the 1st gen Tuono better than the 2nd gen bike I also had. The only thing I could point at was the "lumpier" power delivery.
    I kind of miss it, but am glad it has a good home.
    And am happy with the Monster 1200 that is now my one bike, down from 3 a year ago.
    Ride safe.
    My Tuono suits me to a "T".
    Thunder!
  15. #75
    apriliaforum Junkie Stevex's Avatar
    Jun 2016
    North Yorkshire, England.
    Stunt, you need to cover the bare + terminal, safety an' all that
  1. What did you do with your Falco today?
    By AJJohnson in forum SL1000 Falco Forum (all years)
    Last Post: Yesterday, 01:41 AM
  2. What did you do on your Shiver OR Dorsoduro today ??
    By mh_dorso750 in forum 2008-2016 Shiver 750 / Dorsoduro 750
    Last Post: 08-21-2019, 06:43 PM
  3. What did you do to your Caponord today..!!!!
    By BigSteve in forum ETV1000 CapoNord (2001-2007)
    Last Post: 08-21-2019, 05:00 AM
  4. What did you do to your Mana today ?
    By burningmay in forum 2008-2014 Mana 850 and Mana 850 GT-ABS
    Last Post: 03-16-2015, 11:53 AM
  5. What did you do to your bike today?
    By Sign Guy in forum RST1000 Futura (all years)
    Last Post: 03-21-2012, 10:37 PM
