Page 2 of 33 FirstFirst 123412 ... LastLast
Results 16 to 30 of 485
Thread: What did you do with your TUONO today?
    Dec 2016
    NH
    Should look like... 2 miles later it goes back to normal.
    apriliaforum expert BigGlen's Avatar
    New Rochelle, NY USA
    It actually stays cleaner longer after I took apart and lubed the slave and master piston seals with silicon grease. This was suggested by KZ... on the forum.
    2003 Tuono: Leo Vince slip-on, Factory Pro Chip, custom mapped Power Commander III, HiFlo AFE air filter, '00 snorkle, Forged Alum-Marchesini Wheels, Ohlins Shock, GP Suspension internal Showas, EVO Fuel Pres Modifyer, 525-16/43 final drive (after I wore out the 520), TCM low rear sets, Scorpion Lithium Battery, Pirelli Angel GT's.
    Aug 2010
    Chojnice POLAND
    Preparing for chain kit change.. 110 link DID 525 ZVMX and 16x45 combo...
ID:	348247Click image for larger version.
ID:	348248Click image for larger version.
ID:	348249Click image for larger version.
ID:	348250Click image for larger version.
ID:	348251Click image for larger version.
    Quote Originally Posted by stuntmachine View Post
    That's a beautiful sight! Did you have to use a putty knife to get the gunk off?
    Aug 2010
    Chojnice POLAND
ID:	348304Click image for larger version.
ID:	348305Click image for larger version.
ID:	348306Click image for larger version.
ID:	348307Click image for larger version.
ID:	348308Click image for larger version.
    Today I lubricate dog bone. It was dry but not rusted so it was perfect moment to do it.
    Aug 2010
    Chojnice POLAND
    Some more work done today. Chain is ready to feel Rotax power.. Left radiator removed. Oil leak is massive.. This is job for tomorrow.
ID:	348357Click image for larger version.
ID:	348358Click image for larger version.
ID:	348359Click image for larger version.
ID:	348360Click image for larger version.
    apriliaforum Junkie Stevex's Avatar
    Jun 2016
    North Yorkshire, England.
    Had a leak in the same place, not as bad though.
    Just replaced the cam cover seal and used some Hondabond in the forward left corner.
    Hopefully, no more oil leak.
    Aug 2010
    Chojnice POLAND
ID:	348433Click image for larger version.
ID:	348434Click image for larger version.
ID:	348435Click image for larger version.
ID:	348436Click image for larger version.
    Aug 2005
    Perth W/Australia
    After cleaning it all up, check the lead on/to the starter motor. Mine got corroded once causing bad starts. Rubber boot hides corrosion.
    Cheers.
    Tuono Racing + KTM 990 Adventure =
    apriliaforum Member PSUCJ's Avatar
    Mar 2004
    Lititz, PA
    I recently replaced the cam position sensor, starter solenoid, and spark plugs. A few weeks ago I installed heated hand grips. Rode it to work today. It was about 19 degrees F outside when I left.
    Chris
    2003 Tuono
    Quote Originally Posted by PSUCJ View Post
    THAT'S some chilly riding.
    Aug 2010
    Chojnice POLAND
    All exhaust valves have 0.25 clearance. One intake valve on front cylinder have 0.12 Rest 0.13 easy fit - 0.15 won`t fit. Question is - should I do this 0.12 valve or leave it like this? I put 4000km max next year.. Manual say 0.12-0.17. Engine looks like new inside. 38 000km
ID:	348624Click image for larger version.
ID:	348625Click image for larger version.
ID:	348626Click image for larger version.
ID:	348627Click image for larger version.
ID:	348628Click image for larger version.
    New custom exhaust? Needs fininshing.
ID:	348632Click image for larger version.
    Dec 2012
    Paimio, Finland
    I’d still leave it and would take a peek after 5000-10000 kms/ one year.
    Mille Aarrr -02 (1060 BB, Gen2 heads, 2-2 Akra, timed cams, bespoke Gabro chip + TSS slipper) & KTM 625 SXC -05
    apriliaforum Junkie Ario's Avatar
    Poland
    Installed new speed sensor. When I removed the old one I found out why it was busted. Somehow it has seen to much friction (sic!) somewhere and one lead got broken. So if anyone is looking for a sensor I have one
    BTW I have to remove temp. sensor. Is it possible to do it without taking out the engine?
    Jun 2016
    Did my clearances a few weeks ago and had one intake on a tight .12mm. Talked to Aprilia Performance (UK) who advised that although on the lower limit, it's still within limits, so to leave it.
    Will check the clearances again next winter, as I probably won't do more than 4K miles up to then.
    Bike's got 13K miles on the clock.
  1. What did you do with your Falco today?
    By AJJohnson in forum SL1000 Falco Forum (all years)
    Last Post: Yesterday, 01:41 AM
  2. What did you do on your Shiver OR Dorsoduro today ??
    By mh_dorso750 in forum 2008-2016 Shiver 750 / Dorsoduro 750
    Last Post: 08-21-2019, 06:43 PM
  3. What did you do to your Caponord today..!!!!
    By BigSteve in forum ETV1000 CapoNord (2001-2007)
    Last Post: 08-21-2019, 05:00 AM
  4. What did you do to your Mana today ?
    By burningmay in forum 2008-2014 Mana 850 and Mana 850 GT-ABS
    Last Post: 03-16-2015, 11:53 AM
  5. What did you do to your bike today?
    By Sign Guy in forum RST1000 Futura (all years)
    Last Post: 03-21-2012, 10:37 PM
