Page 22 of 23 FirstFirst ... 1220212223 LastLast
Results 316 to 330 of 333
Thread: JMH's 1060 Big Bore project
  1. #316
    Dec 2012
    Paimio, Finland
    D’oh!
    Some 200 street miles and 80 track day laps later I might have developed a severe gearbox issue.
    So, in order to ride I need to drop this one and put the standard engine in and ride.
    It means going into to this issue won’t be a priority before the season ends. Looks like the engine needs to come apart. Gotta build it better this time then.
    Mille Aarrr -02 (1060 BB, Gen2 heads, 2-2 Akra, timed cams, bespoke Gabro chip + TSS slipper) & KTM 625 SXC -05
  2. #317
    Aug 2010
    Chojnice POLAND
    What issue with gearbox?
    Wysłane z mojego SNE-LX1 przy użyciu Tapatalka
  3. #318
    Dec 2012
    Paimio, Finland
    Bike won’t pull. 1st gear is like 4th gear. Engine idles on neutral and took revs without unhealthy sounds, I can find all gears, I can push the bike (will see about turning the rear wheel the clutch engaged and a gear on). However, I cannot turn the engine from the rear wheel even on 6th gear.
    So, first suspicion is the box.
    Bike stuttered one lap after a missed downshift from third to second.
    We’ll see....
  4. #319
    Aug 2010
    Chojnice POLAND
    Try remove clutch itself and turn gearbox by hand. Sounds like bad bearing or something too tight.
  5. #320
    I would unpack the clutch. Sounds more like clutch or engine. Or could be on the input shaft. With the clutch plates out you should be able to isolate the problem to the gear box or clutch/engine.
  6. #321
    Dec 2012
    Paimio, Finland
    Yep... I thought about that as the clutch needs to come out anyway. If it is OK I want it in the standard engine.
  7. #322
    Dec 2012
    Paimio, Finland
    This is a pretty damn humbling moment. One spark plug wire was loose from the coil. It's working again.
    Do you want me to diagnose issues on your bikes?
    I am happy to help.
  8. #323
    Nov 2011
    devil's elbow, oz
    Dont worry we all have those nanna moments mate. Glad you found it before you started tearing into it.
  9. #324
    Dec 2012
    Paimio, Finland
    Still going strong:
  10. #325
    apriliaforum expert cew's Avatar
    Jun 2010
    Brandon, MS
    Cool pic!
  11. #326
    apriliaforum expert rocketnz's Avatar
    Jun 2011
    Bondi Beach
    LOL - if your modded engine does not struggle to rev in neutral with 1 cylinder running it must be a beast I've had singles running in the early days before my gabro chip, and fouled, and it is very obvious when 1 spark plug is not functioning.
    Anyway great luck for you, great to find a cheap easy fix
    I have not ridden my bike for a month or so, always felt too hard, went for a ride yesterday still love it.
    0̶̶̶6̶̶̶ ̶̶̶A̶̶̶p̶̶̶r̶̶̶i̶̶̶l̶̶̶i̶̶̶a̶̶̶ ̶̶̶S̶̶̶X̶̶̶V̶̶̶ ̶4̶5̶0̶
    99 Aprilia RSV 1000 Mille
  12. #327
    Roma, Caput Mundi
    nice shot!!!
    PS i've got a TTS slipper for my V2 race bike, do you have any tune advice for it?
    PPS i've got an IRC electomechanical blipper as well :P
  13. #328
    Dec 2012
    Paimio, Finland
    I have 3 Barnett heavy duty springs and the TSS spacers that give less slip.
    Clutch plate assembly is exotic as two steel plates go together:
    Engine............................................ .................................................. ....clutch pressure plate
    Standard one:
    1|2|3|4|5|6|7|8|9|0|1|2|3|4|5|6|7|8|9
    $|F|S|F|S|F|S|F|S|F|S|F|S|F|S|F|S|F|S
    Suggested one for TSS:
    F|S|F|S|S|F|S|F|S|F|S|F|S|F|S|F|S|F
  14. #329
    Dec 2012
    Paimio, Finland
    That blipper sounds exciting!
  15. #330
    Roma, Caput Mundi
    OK, i will have something to play with when new clutch showsup
    yes, blipper intallation could be a little tricky, but we are lucky becouse our bikes has the fast idle lever, the blipper actuator can be tied to it:
Name:	IRC universal blipper actuator Gabro Aprilia RSV2 and TuonoV2.jpg
  1. 1060 Big Bore kit WITH CYLINDERS
    By Devildog in forum Aprilia Parts and Accessories for Sale / Wanted
    Last Post: 02-20-2010, 05:02 AM
  2. 1060 Big Bore Kit
    By SteveRens in forum RSVR and RSVR Factory (2004-2009)
    Last Post: 11-09-2009, 04:47 PM
  3. 1060 Big Bore 2007 Tuono Factory - No. VA
    By barmherzigkeit in forum Aprilia Motorcycles and Scooters for Sale / Wanted
    Last Post: 08-10-2009, 07:09 AM
  4. 1060 Big Bore
    By rsvr07 in forum RSVR and RSVR Factory (2004-2009)
    Last Post: 04-08-2009, 10:22 AM
  5. 1060 Big BORE
    By hautzy in forum Tuono 1000 R and Tuono Factory (2006-2010)
    Last Post: 08-31-2007, 08:50 PM
