Results 1 to 3 of 3
Thread: new rider temperture level question
    Aug 2017
    israel
    hello im a new dd1200 rider
    and i have seen that my bike get to 4 bars on temperture and then the fan kicks in.
    some times its drops back to 3 bars and sometime not.
    is that normal with this motorcycle
    Feb 2014
    Bozeman, MT
    4 bars brings the fan on. Mine only got that hot sitting in traffic. I'd worry if you get 4 bars and the fan is not on. Most of the time mine was 3 bars fully warmed up.
    Jan 2016
    Vancouver, BC, Canada
    Mine sits at two bars almost always, but I am not running in stop and go traffic. As long as the fan is coming on you are probably ok. Make sure your coolant level is up and the oilcooler and coolant radiators are clean and free of debris. An aftermarket pipe that removes the cat conv helps with perceived underseat heat build up, and a Fatduc or similar can also help with the factory lean running condition below 5000 rpm which also likely causes some heat. Tom
  1. Two Questions from a New Rider
    By omoplata in forum General Motorcycle Talk
    Last Post: 05-30-2014, 01:10 PM
  2. New Bike Oil Level Question - Factory Over Filled?
    By BlackT5 in forum Tuono 1000 R and Tuono Factory (2006-2010)
    Last Post: 05-15-2010, 03:17 AM
  3. new rider suspension question
    By kidicarus13 in forum 2006-2011 Aprilia RXV, SXV, MXV 4.5/5.5 V-Twins
    Last Post: 05-20-2009, 08:21 PM
  4. New '02 RSV rider - couple of questions
    By Vaprilia in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 08-14-2008, 09:29 PM
  5. New Rider - Falco Questions
    By jec2nd in forum SL1000 Falco Forum (all years)
    Last Post: 09-30-2005, 01:02 PM
