Results 1 to 3 of 3
Thread: Gel Seat
    Apr 2014
    Gold Coast Australia
    Gel Seat
    Has anyone solved the problem of the gel seat seat not latching correctly?
    I've had it for about 18 mths now and personally I'm sick of ****ing around with it!
    I've tried adjusting the latch, adding washers under the lock etc.
    ANY advice gratefully accepted.
    Geoffa
    Feb 2014
    Bozeman, MT
    I got it to work by putting two washers under each bolt on the latch. that finally did it. One washer worked for the stock seat.
    Apr 2014
    Yeah thanks xactoman. This is what I've been doing. It works for a little while and then pops loose again.FRUSTRATING! I go through different washer thicknesses and combinations with varying results. It seems to me to be the "plate" in the latch itself not protruding far enough. I never had a problem with the stock seat.
  1. Gel seat for Dorsoduro
    By zzyzx in forum 2008-2016 Shiver 750 / Dorsoduro 750
    Last Post: 08-09-2009, 08:34 AM
  2. Gel seat for SXV 550 ?
    By ADROCK in forum 2006-2011 Aprilia RXV, SXV, MXV 4.5/5.5 V-Twins
    Last Post: 09-27-2007, 01:29 PM
  3. Aftermarket Gel seats?
    By cosaro in forum General Motorcycle Talk
    Last Post: 06-20-2006, 11:46 PM
  4. Small butt needs an air/gel seat
    By systemone in forum Aprilia and Piaggio 500cc
    Last Post: 02-01-2006, 04:52 PM
  5. Pro-pad gel seat
    By Caponerd in forum ETV1000 CapoNord (2001-2007)
    Last Post: 06-21-2004, 12:41 PM
