Results 1 to 3 of 3
Thread: 250ie/300 preferred clutch setup??
    Jun 2016
    Florida
    Looks like my low mile 250ie may need a clutch or maybe better springs.
    Its just a stock motor with a 9 weight variator with matching spring and the clutch likes to "stick". Sometimes it will disengage under 15mph when coasting... sometimes not. I like the free wheel feeling when not on the gas. I assume the springs get fatigued? Any way to measure or benchmark? Or could it be the original drive belt is bad? Last time I serviced it the belt had no signs of wear or fatigue (frayed fibers)also I beveled the clutch pads and resurfaced the bell.
    Do heavier springs change engagement RPMs?
    Jun 2016
    Florida
    mines fuel injected so its not the pilot or main...hehe.
  1. Dry Clutch Setup
    By gts455 in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 02-06-2015, 05:31 PM
  2. Variator noise, variator / clutch setup
    By dansan in forum Scarabeo 50 Ditech, SR 50 Ditech, SR Factory
    Last Post: 04-01-2014, 10:47 AM
  3. Clutch setup HOWTO
    By amolea in forum ETV1000 CapoNord (2001-2007)
    Last Post: 06-21-2009, 07:46 AM
  4. Clutch setup question(new cable)
    By boinovRS in forum RS250
    Last Post: 08-11-2006, 04:45 PM
  5. WANTED TO BUY: Dry clutch Setup
    By SteveLL in forum RS250
    Last Post: 08-30-2004, 07:50 AM
