Results 1 to 9 of 9
Thread: Instrument lights on, speedo/display not working
    apriliaforum newb dirtbeard's Avatar
    Jun 2010
    Palos Verdes, CA USA
    '07 SXV450 was fine until I changed the battery. Now it runs fine, lights, turn signals, are normal, but all of the dashboard lights other than the fuel stay "steady on" while the display is blank.Click image for larger version.
    I detached the battery for five minutes with the key on, tried the display functions, etc., but to no avail. I am hoping, of course, that it is not the actual display unit.
    doug
    ________________
    '72 BSA B50SS
    '01 HD XHL 883
    '03 GMC Cargo Van
    '07 Aprilia SXV 550
    '13 Aprilia Tuono V4R
    Feb 2009
    Tri-Cities, Washington
    Did you get both of the wires connected on the negative terminal?
    Jun 2010
    Thank you, yes, I have the two on the negative terminal (thick one for the starter and the multi-wire one.
    doug
    ________________
    '72 BSA B50SS
    '01 HD XHL 883
    '03 GMC Cargo Van
    '07 Aprilia SXV 550
    Apr 2019
    Venezuela
    Question Problem
    Quote Originally Posted by dirtbeard View Post
    I have the same problem help
    Jun 2010
    Quote Originally Posted by Jorman diaz View Post
    It ended up being a bad display/dashboard. I sourced another display from a totaled SXV. It has been working fine.
    The part number is AP9100516 and costs $429 new.
    Hope that is not your problem, too.
    doug
    ________________
    '72 BSA B50SS
    '01 HD XHL 883
    '03 GMC Cargo Van
    '07 Aprilia SXV 550
    Jun 2012
    Greece
    damn....this is my problem too...
    tried today to see the fuses near exhaust but nothing.... my dash is freezed...
    maybe its time for an aftermarket one
    Jun 2012
    Greece
    anyone know how should i wire temporary a led light just for low fuel warning?
    Is that possible?
    Feb 2009
    Switched battery power to LED, other side of LED to the yellow / green wire on the display connector.
    Jun 2012
    Greece
    Quote Originally Posted by SXVINWA View Post
    thanks!!
  1. Speedo sensor not working ...
    By Nilfisk2000 in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 02-27-2016, 06:11 PM
  2. Temp in display not working
    By Hansie in forum SL1000 Falco Forum (all years)
    Last Post: 07-14-2010, 03:00 AM
  3. sl 1000 falco temp display not working
    By piro in forum SL1000 Falco Forum (all years)
    Last Post: 10-19-2009, 02:20 AM
  4. digital display not working- Help!!
    By jz1489 in forum RS125 Euro-archive
    Last Post: 07-30-2006, 04:04 PM
  5. Stop Light ON Constantly (does not go off)!
    By RJS993 in forum Pegaso 650 Cube and IE
    Last Post: 01-06-2004, 04:40 AM
