Results 1 to 10 of 10
Thread: What do I need to install 50mm Marzocchi forks on my SXV?
    May 2011
    The Island and the Mountain
    I have some 50mm Marzocchi forks off my TM 250 dirt bike. I would like to install them on my 550 SXV. How to I find triple clamps and do I need anything else for the brake?
    apriliaforum expert SSwest's Avatar
    Oct 2012
    Huntington Beach, CA
    First you'll need some 50mm triple clamps. Faor and X-Trig offer some. Depending on the fork bottom you could require a caliper bracket to possibly a different caliper. Pics?
    Feb 2009
    Tri-Cities, Washington
    I would think a set of MXV triples would be an inexpensive option.
    May 2011
    May 2011
    I see an MXV top clamp and a VDB bottom clamp on ebay. Probably can't combine the two to work. It may be interesting to find the clamps.
    apriliaforum expert Allen Noland's Avatar
    Nov 2008
    Mountain Lake Park, MD
    Quote Originally Posted by MrBoom View Post
    Correct, they can't be combined but there are 3 different OEM clamps that will work. In addition to the MXV and VDB, the triples from the 2012-13 Euro model SXVs were made for the 50mm Marzocchis and can be used with the stock dashboard/headlight without having to fab anything.
    Noland Trans-World Cycle
    7 East 1st Ave. Mountain Lake Park, MD 21550 * Phone (301) 616-2034 * e-mail allennoland@yahoo.com
    http://www.facebook.com/NolandTransWorldCycle
    Westminster, CA - USA
    Actually you can combine an MXV top clamp with a VDB bottom clamp.
    The MXV is a fixed 14mm offset and the VDB can be set to 11, 14 or 17mm depending on what eccentric you use.
    Another option is to PM me and I'll sell you a complete set of MXV t-clamps I have, they're new.
    What type of brake caliper does that TM fork use?
    Nov 2008
    Every set of stock MXV triples that I've seen had the same 21mm offset as the RXV/SXV clamps. Are the 14mm clamps you have some kind of factory racing exclusive?
    I'll have to go and double check Allen
    I got these MXV clamps a few years ago in a package with a bunch of parts from from Italy.
    They were not in the original packaging, just labeled with a tag hand written 14mm.
    So I can't say for sure these are std MXV clamps.
    You've seen a lot more MXVs than I have, so if you say std is 21mm I'm sure you're correct.
    May 2011
    I am still trying to decide on using these forks on one of the SXV's. Does anyone know of a bracket or other way to use the bigger Brembo caliper and rotor from the SXV on the Marzocchi dirt forks?
  1. What do I need to make the bike start easier?
    By Brian_M in forum RST1000 Futura (all years)
    Last Post: 02-11-2009, 11:04 PM
  2. 07.5 RSV brand new...what do i need to know?
    By Highway9Rider in forum RSVR and RSVR Factory (2004-2009)
    Last Post: 08-07-2007, 01:13 AM
  3. what do i need to do before i put stickers on
    By 01dabreoo in forum RS50 Technical
    Last Post: 06-28-2006, 09:35 AM
  4. What do i need to buy??????
    By 98shaikh in forum RS50 Technical
    Last Post: 07-02-2003, 02:45 PM
  5. What do I need to for the tuneboy?
    By mnrstrider in forum RST1000 Futura (all years)
    Last Post: 02-08-2003, 11:16 AM
