Results 1 to 2 of 2
Thread: Engine suddenly stopped working
    apriliaforum prov-nov steelsey's Avatar
    Oct 2011
    Derby, UK
    Finally sorted the clutch on my SXV when out on it yesterday the bike suddenly stopped working. I was doing about 70mph when the bike instantly went onto one cylinder. When I came to a stop I tried to keep it running but it stalled and would not restart only occasionally firing up on one cylinder then cutting out.
    I hoped it was a spark plug so checked them to see if they are working and they were if not bloody black (see picture) I removed the tanks and airbox and turned the engine over to see whats happening. On a few rotations the rear cylinder did fire but the front is dead...Could this be an injector issue? Or is this another bloody problem with SXVs?
    Attachment 318840
    Dec 2007
    Buffalo WY
    Cool
    [QUOTE=steelsey;4154925]Finally sorted the clutch on my SXV when out on it yesterday the bike suddenly stopped working. I was doing about 70mph when the bike instantly went onto one cylinder. When I came to a stop I tried to keep it running but it stalled and would not restart only occasionally firing up on one cylinder then cutting out.
    I would check all wiring from coil connections down to the area of battery. When my bike was purchased it had a wire that came out of a connector somewhere in the battery area that would shut down at low rpm and when rpm picked slowly it would kick in and you had a abrupt gain in power, which was a little unnerving in traffic. Dealer sorted it out the next day. So connections might be the issue.
  1. Engine suddenly stopped working
    By steelsey in forum 2006-2011 Aprilia RXV, SXV, MXV 4.5/5.5 V-Twins
    Last Post: 10-06-2016, 02:07 PM
  2. Instrumentpanel suddenly stopped working
    By Daniel_ in forum 2006-2011 Aprilia RXV, SXV, MXV 4.5/5.5 V-Twins
    Last Post: 07-17-2014, 02:52 PM
  3. Speedo stopped working
    By gregsblade in forum SL1000 Falco Forum (all years)
    Last Post: 01-25-2005, 01:48 PM
  4. Replies: 5
    Last Post: 10-26-2004, 07:39 AM
  5. Cooling fans stopped working
    By BulletR in forum SL1000 Falco Forum (all years)
    Last Post: 03-20-2003, 07:38 PM
