Page 6 of 10 FirstFirst ... 45678 ... LastLast
Results 76 to 90 of 139
Thread: GuzziDiag step by step throttle and handle learning procedure for RSV4 and Tuono V4
  1. #76
    apriliaforum expert the todd's Avatar
    Jun 2014
    Ball Ground
    Ride somewhere that you can go 25mph without traffic, Go to the menu on your dash and select calibrate, get up to 24-25mph in second gear stay there as long as you can and the menu on you dash will go back to normal, stop turn off the key switch and the turn it back on and then you will need to turn the tc on and set everything to the mode you want.
  2. #77
    Jan 2016
    Australia
    Quote Originally Posted by Julzrat View Post
    Just finished installing race ecu throttle leading and handle learning done. How do i calibrate TC WC ABS AND LAUNCH CONTROL?
    Calibrate isn't in the menu now. WTf?
    No speedo nothing? Any help or tips?
  3. #78
    apriliaforum prov-nov TGR007's Avatar
    Jan 2012
    Tassie, Australia
    If you have an APRC model then your race ECU fitted doesn't have the APRC setting enabled. No speedo, TC, AWC or Launch control until this is enabled. Once turned on Calibration and APRC settings from the dash menu will be visible.
    Take to an Aprilia dealer to connect the PADS software for the APRC to be enabled, also have them check Quickshift & ABS (if equipped) settings are turned on.
  4. #79
    Jan 2014
    ukraine
    Hey. Tell me, can I do the throttle calibration using this program?
  5. #80
    apriliaforum expert skabarbro's Avatar
    Mar 2014
    Harrisburg, PA
    Yes. Throttle learning and handle learning.
    2012 Tuono V4 (Golden Ape for sale)
    2012 Tuono V4 (Sold)
    2010 RSV4 R (wrecked)
    2008 YZ450F Sumo (traded)
    2006 YZF R6 (Sold)
  6. #81
    apriliaforum prov-nov garet's Avatar
    Mar 2016
    iowa
    wish it was easy as just following the steps but like many others it says disconnected and when after following instructions to turn ignition it waits a few seconds then says turn off and does nothing....i tried both programs just wont work
    -Garet
    2014 Tuono V4R ARCP-White with carbon Akrapovic slip-on, 15T front sprocket, Light tint MRA touring screen, R&G frame sliders, & 2016 Tuono seat
    2012 suzuki V-Strom 650 Adventurer-Black no mods. What a great first bike. (sold)
  7. #82
    Jun 2011
    Central Cali.
    It's likely a bad blue cable. I ordered a different one and tool care of the problem and was loaded in just a few seconds.
    Sent from my SAMSUNG-SGH-I337 using Tapatalk
  8. #83
    Mar 2016
    iowa
    what are the odds of that i wonder....would be my luck though
    -Garet
  9. #84
    Jun 2011
    Central Cali.
    Quite a few people have had a problem with that cable.
  10. #85
    Mar 2016
    iowa
    I actually just did a adaptor test to ensure its working and it said its functioning properly so its not the cord as i expected.
    -Garet
  11. #86
    Mar 2016
    iowa
    i got her sorted out. thanks for the help all.
    -Garet
  12. #87
    Oct 2015
    Tasmania
    Quote Originally Posted by garet View Post
    Come on don't keep us in suspense; what was it??
  13. #88
    Mar 2016
    iowa
    i needed to download FTDI driver and.....connect positive back to battery lol. could have sworn i read to make sure and disconnect after removing seat. must have got threads mixed up or something as i cant find where i read it now. enjoy the laugh noob out, G lol
    -Garet
  14. #89
    Oct 2015
    Tasmania
    Well thank you for being honest, we've all done the dumb things, felt like a retard & it's hard to admit it.
    You probably just saved someone else from making the same mistake.
    EDIT: BTW, the Lonelec cables come with a step by step instruction on installing cable & driver as well as how to verify correct installation before you connect to bike.
  15. #90
    Mar 2014
    Harrisburg, PA
    Glad it worked out for you!
    2006 YZF R6 (Sold)
  1. Replies: 308
    Last Post: 08-16-2019, 07:22 PM
  2. Installing new rear end gears-STEP BY STEP w/PICS, and performance results!
    Last Post: 04-06-2018, 03:42 PM
  3. Learn how to DE-RESTRICT here!! step by step w/PICS!!
    Last Post: 04-25-2017, 11:51 AM
  4. Race ECU and handle learning Procedure
    By Bassgt3 in forum 2010-2019 RSV4 - All Variants
    Last Post: 09-19-2012, 03:31 AM
  5. Replies: 38
    Last Post: 06-03-2012, 09:16 AM
