Page 3 of 10 FirstFirst 12345 ... LastLast
Results 31 to 45 of 139
Thread: GuzziDiag step by step throttle and handle learning procedure for RSV4 and Tuono V4
  1. #31
    apriliaforum expert Eppy's Avatar
    Dec 2007
    Westminster, MD
    Quote Originally Posted by letsride View Post
    Just got my ECU back from AF1 and installed it,now trying to program the throttle and having trouble.Everything is connected and when I click on connect on the screen,a window pops up that says turn on ignition then comes back and says turn off.Won't let me go to actors to select what I need to do.Any ideas?
    You figure it out?
    My ECU is heading to AF1 now... curious what the issue is in case it happens to me..
    Mark~
    2010 - RSV4 - Street
    2016 - Multistrada - Street
    2004 - GSX-R 750 - Track
  2. #32
    Jun 2011
    Central Cali.
    No,not yet.
    Sent from my SAMSUNG-SGH-I337 using Tapatalk
  3. #33
    apriliaforum Member NixK7's Avatar
    Jan 2015
    Carlisle UK
    Mine does that from time to time, usually the connection between the two separate cables where the two larger plugs go together. mine were a crap fit from new and took some wiggling to get a good contact on all pins
    Also try another USB port
    2014 RSV4 Factory ABS
    SC Project GP
    PCV,SFM,AT
    Race ECU
  4. #34
    apriliaforum expert Danfinarch's Avatar
    Dec 2013
    Hampshire
    I had this today while I was using IAWdiag, three or four times. Reverted back to GuzziDiag and it worked first time. No other explanation sorry. But going to Guzzidiag sorted the issue for me
    2009 R
    Race ECU. Domino XM2, Shorty Akrapovic. Retro Fit APRC Qs. RCS 19 and RCS clutch perch
    HEL lines throughout. GiaMoto Rearsets, Puig, Pipercross Air filter. SC1 for road and Superbike Slick SC1/SC2 track
  5. #35
    apriliaforum expert the todd's Avatar
    Jun 2014
    Ball Ground
    I'm not sure of what is causing the problem, the connection must be ok at first and then something is losing contact, it could be software related, try uninstalling and reinstalling everything. If it still happens, it might be a cable failure.
    Is the data loading from your ECU in to Guzzidiag?
  6. #36
    Jun 2011
    Central Cali.
    Quote Originally Posted by the todd View Post
    I have reinstalled everything and still have the same issue.The data is not loading from my ecu
  7. #37
    Dec 2013
    Hampshire
    Go to device manager, look under COM PORTS and there will be a yellow warning triangle on the symbol. Click on that and it'll say the drivers for that device are not up to date. Update the drivers for the cable and it'll work
    2009 R
  8. #38
    Jun 2011
    Central Cali.
    Quote Originally Posted by Danfinarch View Post
    Tried it,the driver is updated still not working
  9. #39
    Jun 2011
    Central Cali.
    When I go to gussidiag,on the bottom of the page it says disconnected.
  10. #40
    Jun 2014
    Ball Ground
    It sounds like a cable problem. Is the light working on the cable?
  11. #41
    Jun 2011
    Central Cali.
    yes it is
  12. #42
    Jun 2014
    Ball Ground
    That's strange, if you have a dealer near by, that might be your only option to avoid more frustration. I would come over and help if I weren't 32 hours away.
  13. #43
    Jun 2011
    Central Cali.
    The nearest dealer that could help is a couple hrs. away.Ordered another cable,hopefully that is the problem.If not then I guess I'll have to take it to them.
  14. #44
    Jun 2014
    Ball Ground
    Where are you getting your cables?
  15. #45
    Jun 2011
    Central Cali.
    I'm going to order the ones that pumpiniron recommended.The blue cable I have,I got from ebay that has been used before. Maybe got a bad one.
  1. Replies: 313
    Last Post: Today, 09:59 AM
  2. Installing new rear end gears-STEP BY STEP w/PICS, and performance results!
    Last Post: 04-06-2018, 03:42 PM
  3. Learn how to DE-RESTRICT here!! step by step w/PICS!!
    Last Post: 04-25-2017, 11:51 AM
  4. Race ECU and handle learning Procedure
    By Bassgt3 in forum 2010-2019 RSV4 - All Variants
    Last Post: 09-19-2012, 03:31 AM
  5. Replies: 38
    Last Post: 06-03-2012, 09:16 AM
