Results 1 to 5 of 5
Thread: Grrrrr save me
    Sep 2016
    Ohio
    Grrrrr save me
    So, mp3..low miles bought used..
    Battery does within 12 miles
    Buy new one.... dies, engine shuts off WIthin 12 miles..
    Carry both batteries , swap when engine dies , same thing..
    Take to dealer..
    He buys a third batteryear, same thing again..
    So, he replaces stator .. and some other stuff.. he claimed old stator read zero output..he never actually told me he verified new stator has output, but that's assumed..
    Pick up scooter, brand new battery, new stator , thermostat , oil change..
    Drive it around a bit.. seams ok..took it out for a ride against my better judgment... mostly higway... come to a stop sign..engine sputters, then dies.. hit start button.... nothing..
    Voltage regulator you think ? Other issue
    P.s. I'm sure just by chance but everytime it does this it seams to occur when I'm using the lock button... in reality in sure that's irrelevant and it's more to do with low rpms at a stop sign
    Jun 2013
    croatia
    check if the battery is charging at all
    bad voltage regulator, and blown fuse can be a often problem
    eventualy the bike runs as long as there is sufficient electricity when the battery is depleated the pump and computer shut off and the bike is dead
    Sep 2016
    Ohio
    Yes, for sure the battery is dead when it stalls out... I can fully charge , and get about 15 miles on it, at idle it just shuts off.. what fuse could cause this ?
    Jun 2013
    croatia
    any fuse in the fuse box should be fine or replaced if faulty
    also check if the voltage regulator is working at all it should be getting ac current from the magneto and put out 13-14.7V
    apriliaforum newb BVL123's Avatar
    Nov 2015
    BVL123
    Keeping Piaggio Battery in Good Condition
    I am not an expert, but I did notice something like this with my 2008, MP3 400cc. I made a couple changes to how I stored my Piaggio. First, I make sure that I always store the scooter with a trickle charger attached to the scooter to top off the battery. Second, whenever the front wheel locks are engaged, that is using power from the battery to keep the two front wheels locked. I only use the wheel lock to keep the MP3 standing on it's own for short stops (a couple hours). I use the bike stand and "turn-off" the wheel lock when leaving the scooter for protracted periods of time (overnight). Since I instituted those behaviors the battery has held up just fine. I hope that helps.
  1. Save me tomorrow, NJ/Pa. Capoisti!
    By wpbarlow in forum ETV1000 CapoNord (2001-2007)
    Last Post: 04-04-2009, 06:08 PM
  2. Holy Cowpie! You guys just saved me from a nightmare!
    By pfb in forum 2006-2011 Aprilia RXV, SXV, MXV 4.5/5.5 V-Twins
    Last Post: 09-19-2007, 12:45 PM
  3. save me noah
    By MIKETRIBAL in forum SL1000 Falco Forum (all years)
    Last Post: 10-24-2006, 04:13 PM
  4. my ditech saved me and my girlfriend.
    By nickybee in forum Scarabeo 50 Ditech, SR 50 Ditech, SR Factory
    Last Post: 09-05-2005, 04:30 AM
  5. Mikes grille saved me
    By RinOz in forum ETV1000 CapoNord (2001-2007)
    Last Post: 12-02-2003, 08:11 AM
